Send a message via AIM to TheCooler
Project TheCooler's 944S2 Build Up Thread
So instead of making a million posts Ill just make this one to explain what's happening with my engine install.
-Tonight I took off my old clutch, bell housing, pressure plate, and flywheel
-Clutch looks like it only has 50% left to it I will keep it for now to save money
-Took off the new oil pan in inspected everything in the new engine
-Oil pan looked very clean as well as the inside of the engine (Just a little gunk at the bottom...no metal shaving to be found)
-Put a new oil pan gasket on
****While putting the gasket on I heard a loud pop while i was torquing the bolts ...Has this ever happened to anyone else? I inspected everything and didn't see anything broken or cracked*****
To do list for tomorrow
-Put old clutch assembly on new motor and wait for parts to come in.
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 05-17-2006, 09:12 PM
Maybe it was one of those Aluminum thick washers imbeded in the gasket settling in it's place?
Jaime O.
Thank god I crashed or i would never have owned a porsche
83 944 daily driver (clutch and tt time)
85 325e BMW T-boned R.I.P.
Old 05-17-2006, 11:23 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
My guess is that the oil pan was bound up on the threads of one of the bolts and when there was finally enough pressure to force it loose, it made the snap noise.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 05-18-2006, 02:58 AM
Yeah i figured it was one of those washers....I hate torquing that damn oil pan, It takes forever.
-87 VW GTI 1.8 16v
-1999.5 Jetta VR6
Old 05-18-2006, 06:14 AM
PICTURES!!!
My new car
New Engine
Old Engine
I need to clean this up eh?
Misc parts
-87 VW GTI 1.8 16v
-1999.5 Jetta VR6
Old 05-19-2006, 11:49 AM
MORE PICTURES!
More dirty engine bay
Dirty ass garage
Can you say control arm rebuild?
Does it really look bent like that?
Fedex brought me presents
-87 VW GTI 1.8 16v
-1999.5 Jetta VR6
Old 05-19-2006, 11:50 AM
dsalillas's Avatar
If you don't mind me asking. What was wrong with the old engine?
nm, I found the post stating you spun a bearing. How bad is the block? I have a friend looking for a decent block.
84 944 (RIP)
85.5 944 (RIP)
88 944S (about to be parted)(traded for S2 Engine)
90 944S2 Cab. (finally running after head surgery)(now with a new engine)
Old 05-19-2006, 09:59 PM
Yeah i spun a bearing...im sending back the old engine though
-87 VW GTI 1.8 16v
-1999.5 Jetta VR6
Old 05-19-2006, 11:31 PM
Project has been put on hold ...Im at Yale New haven hospital right now. I stole a plug from a computer here and hooked up my laptop. I guess theres something wrong with my kidneys . Theyre only functioning 20% of what they should. Ill probably be here for a while. I have this intense pain in my back and stomach also. This is hell...thank god for pain killers though.
-87 VW GTI 1.8 16v
-1999.5 Jetta VR6
Old 05-28-2006, 01:22 PM
Just finished the front end rebuild
-Redid seals
-Waterpump
-Belts
-Checked cam chain tensioner and pads
-Replaced valve cover gasket and spark plug gaskets
-Replaced spark plugs
Now the engine is ready to go in
-87 VW GTI 1.8 16v
-1999.5 Jetta VR6
Old 06-13-2006, 08:18 PM
Glad to see it's all coming back together. Hope your Kidneys are doing better.
I'm sure that you thought of this but you should probably do the Balance shaft gaskets while it's out. (one of mine is leaking a bit) That A-Arm Ball joint looked pretty beat. Was the Steering sloppy. There are some drill out ball joint kits out there where you can replace the old rivet ones without forking out for an whole new A-Arm.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 06-14-2006, 09:07 AM
Best wishes on your health...and Porsche
89 Porsche 944
Owner: AutoFreeFinders.com Online Auto Mall
Old 06-14-2006, 09:57 AM
Yeah im going to redo the balljoints once I can get my paypal account to work.
-87 VW GTI 1.8 16v
-1999.5 Jetta VR6
Old 06-14-2006, 10:03 AM
The engine is in!!!!
The only problem Im having is getting 1 motor mount bolt in right near the headers. I have no space and the sucker doesnt want to spin easy. Is there a trick?
Next thing i need to do is hook up the external oil cooler, coolant lines, electrical wiring and fill it with fluids.
-87 VW GTI 1.8 16v
-1999.5 Jetta VR6
Old 06-20-2006, 03:43 PM
I like to loosen up the 4 cross member bolts alot, first. also make sure the other engine mount bolt is in but very loose. Then tighten a little on each mount.. then same for the cross member. Also a jack under the center of the cross member supporting but not pinning the cross member to the frame.
Did you light it up yet.. Good Luck
Old 06-20-2006, 03:53 PM
No i havent started it yet. I want to get all the coolant connections on before i do. Im going to fill it with distilled and something to flush it out then put in 50/50 just so i dont put in coolant then find a leak. I bought mobil 1 15w50 ..cost me 36 dollars
-87 VW GTI 1.8 16v
-1999.5 Jetta VR6
Old 06-20-2006, 07:17 PM
Just got an insurence quote on it... 90 bucks a month. Not too bad.
-87 VW GTI 1.8 16v
-1999.5 Jetta VR6
Old 06-21-2006, 07:05 AM
