Want bigger brakes! Do 928/968 brakes bolt on directly to my 86 951?
Hey guys just wondering the best way for more stoppage?? I am told by a very credible tech that 928 brakes would be best. Are these bolt ons? Conversion kits? Master cylinder change out?
Any tips would be great! Brock 86 Zermatt 951
That Guy
The 968 brakes are the same ones on your car right now. You want the Turbo S calipers or 928S4 calipers..aka the Big Blacks.
Take a look here for good information regarding upgrading to something bigger.. http://www.944s2.com/default.htm
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
If you go with those Turbo S calipers (also the same as 993 C2/C4), you'll also need figure out a mount -- either replace the steering knuckles or use an adapter (same adapter as those used for mounting Big Reds).
But IMHO, the best way for better stoppage is simply making sure your rotor/pads/fluids aren't worn out and having good tires.
Joe Chen Current fleet: '93 Amethyst Violet 968 Cab "Lila" (back in the fleet!) ; '92 Cobalt Blue 968 Cab "Minjonet" - Canadian car '88 Silberossa 951S "Rosy" - garage queen ; Secret project ; '99 Ford Ranger ; '00 Kawi ZX6R Former cars: '94 Black 968 Cab "Steffi" (totaled) '87 Nautic Blue 944 S3 "Emma" (blown motor) ; '90 White 944S2 ; parts cars
Dog-faced pony soldier
Hey now! Didn't you just buy a set of them there Wilwoods!
Have to agree though - four little patches. Nothin' like good tires. As a simpler/easier way to get more stopping power you might consider a 5/33 brake bias valve. IIRC Paragon and a couple other places carry them. The rear brakes on the 951 are somewhat under-utilized and increasing the bias to strengthen the rear braking a bit has been known to help. Make sure not to brake too deeply into your first corner after installing or you might get a nasty surprise. . .
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
