removed a/c what size belt do i need??
remove a/c compressor,what size belt do i need to run without it. 1984 944 non turbo?
How are you going to tension the belt?
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
not sure,what do i need to do
You have to get an A/C delete bracket. The alternator does not tension the belt on the combo bracket.
would it just be better to buy a used compressor?
About the same cost -- $150. If you can find a delete bracket.
