TNT25169's Avatar
Send a message via AIM to TNT25169
Cross member ground wire
I found my wire that I removed from my cross member when I removed my power steering rack. I know one end connects to the sheet screw in the cross member but where does the other end go? It's about 6 inches long. Thanks.
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 06-04-2006, 01:19 PM
SoCal Driver's Avatar
Same type of tapped hole on the steering rack. This is the ground wire for the horn.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-04-2006, 01:55 PM
TNT25169's Avatar
You told me it was the ground for the horn but at the time I was convinced the wire was coming from somewhere else under the car. Turns out I found the wire sitting on the floor of my garage. I'm going to go home from work and see if I can find this other hole in the steering rack. It's amazing, I rebuilt the steering rack as well as my entire front suspension several times but sometimes I feel like I'm retarded.
www.apartabove.com
Old 06-04-2006, 04:01 PM
Just thinking out loud
mattdavis11's Avatar
Won't see it til you drop it. IIRC, it's on top of the rack near the input shaft, or there abouts. Why bother though the entire rack is bushed, tap a new ground if need be.
91 FJ80
84 Ram Charger (now gone)
Old 06-04-2006, 09:50 PM
TNT25169's Avatar
is it going to leak? I don't remember seeing a screw like the one on the crossmember going into the steering rack. To my knowledge it came from a hole with a bolt on it. If this is correct, can't I just connect it to any bolt on the rack? I don't even think my horn worked in the first place...hmmm, I might just leave this one off if grounding the horn is its only purpose.
www.apartabove.com
Old 06-04-2006, 11:04 PM
Zero10's Avatar
Send a message via ICQ to Zero10
Mine is connected to a 10mm head bolt (M6) on the front of the rack. There are 2 bolts holding a plate on, and the plate extends to the side and has an extra bolt hole for the ground wire.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 06-05-2006, 04:32 AM
Mine is the same set up as mentioned by Zero10
Old 06-05-2006, 07:41 AM
TNT25169's Avatar
Then a 10 mm bolt on the tensioning plate it is. Thanks again guys.
www.apartabove.com
Old 06-05-2006, 08:06 AM
TNT25169's Avatar
After looking at it I realized it's the same bolt that the steering hose uses as a mount. I remembered taking it off of here, all is right with the world again, it's just been a few long weeks.
www.apartabove.com
Old 06-05-2006, 03:55 PM
So if one were to attach the small connector to the crossmember at the treaded boss then move the other end around at it's limit in a big circle you would figure out where it attaches to.
Old 06-05-2006, 04:11 PM
TNT25169's Avatar
Yeah, I never claimed to be smart, oh well.
www.apartabove.com
Old 06-05-2006, 05:14 PM
