Need early 944 window wiring diagram
I can't seem to find these thru searches or in the workshop manual. Basically i'm trying to trace a short or draw of current in the window circuit. I'm getting only 8v on the pass side harness and none of my switches are working. Fuse seems to be good and relay is warm to the touch, no corrosion.
If anyone can provide me with the diagram or shed some light?
-Frank '83 944 '10 997.2 Guards Red GT3 Prev: '84 944, '16 M3., '15 STI, '14 500 Abarth, '08 135i |
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Hugh, you are the best...i swear i couldnt find it in the tech area!!!!
Go to the image and back up a page or two. Bookmark it.
