Help
anyone have ideas on how to take the nut off the front strut assembly? the one with the allen bolt in the middle? thanks
84' 944
Old 07-02-2006, 11:11 AM
Will work for parts
944 boy's Avatar
Send a message via AIM to 944 boy
Go to a parts store and buy an oxegen sensor removal tool. It allows you to get an allen or socket in the middle to hold the strut shaft. Make sure you have a spring compressor on the spring if you have stock springs first.
'88 944 240,100 miles -race car
'05 Boxster 110,000 - Daily Driver
'74 911 Targa - long term project
Old 07-02-2006, 11:27 AM
Impact Wrench.
Good luck, George Beuselinck
Old 07-02-2006, 12:10 PM
SoCal Driver's Avatar
If you are planning on doing the inserts (shocks) I would take the entire strut out first. The two large bolts at the spindle and the four nuts/studs at the top. Once the strut is out you can get the spring compressors on it and have at the top nut.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-02-2006, 03:00 PM
