-   -   No Cat, need 2 use an O2 sensor? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/291251-no-cat-need-2-use-o2-sensor.html)
924Sman 07-01-2006 03:53 AM
Any need for the sensor running race pipes and no cat? My car seems to run better disconnected or my drugs are really working well.;)
Curious little man....
Dal
arnebret 07-01-2006 04:30 AM
The O2 sensor gives essential feedback to your engine management about the state of your combustion. I think the management system will go to a sort of backup scheme when the O2 sensor is lost, so it will run fine, but not as efficient or clean as it should.
Now, with racing clean or efficient isn't really the sort of quality you're looking for in an engine. What most people seem to do when they take one of these cars racing is installing a wideband O2 sensor to get a more precise reading and with that reading being able to make very precise adjustments to the amount of injected fuel, resulting in a more efficient engine, powerwise. Now that you want... ;)
924Sman 07-01-2006 05:01 AM
Yep arne I am aware of the DME going to a richer mixture( open loop) once up to full temperature. Was a bit too lean so I disconnected it to gain a richer mixture, plugs are not as platinum white as prior, now getting more of a cream color which is good. Does appear that the mileage has dropped but expected that.
O2 is before the cat anyway so I think my question is null.
Dal
Eldorado 07-01-2006 07:59 AM
get a wilks chip if you dont wanna run an o2 sensor ;)
924Sman 07-01-2006 08:05 AM
Funny you mention it, next weekend or thereabout a PP2 is going in.
Dal
Eldorado 07-01-2006 09:37 AM
then dont worry about your o2 sensor...
924Sman 07-01-2006 12:03 PM
Wasn't worried just curious if it was needed w/no cat. Did recall the lack of need for the O2 after it was mentioned.
Dal
