oil/air separator location?
I've heard a lot of people saying that oil in the intake system usually means bad oil/air separator seals. I've bought what I think are the right seals (found them on another post) and I want to change them. Could someone please show me which part the separator is (a nice little red arrow on the picture would help a lot!)? I've attacked a picture of my engine bay with the intake manifold removed (beware! looks pretty nasty under there).
Also, what's a good way to remove the oil from the other intake parts (IC pipes, intake manifold, etc.)? Should I take them to a machine shop and ask them to acid dunk them or what?
Thanks all
'86 951 blk/blk
-968 M030 Sway Bars with delrin bushings
-IceShark headlight kit
-Koni Yellow Sport Adjustable struts and shocks
-225 lb springs up front
Cleaned grounds = happy 944
WTB: 951 black passenger door/fender
Old 07-01-2006, 05:09 PM
SoCal Driver's Avatar
If you have two o-rings (a little flattened) about 1 1/4"'s in diameter then take off the big black plastic thing under the yellow oil fillter cap.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-01-2006, 06:12 PM
Politically Incorrect
onZedge's Avatar
Hey, I just did this last week !!
The oil separator is the plastic thing that the #710 cap screws on to. Three 8mm bolts. I changed out ALL the rubber hoses, tubing, o-rings and clamps I could find while I had the intake manifold off. The only thing I missed was the oil dipstick grommet. At least that one is easy.
Also rebuilt the throttle body. DGV's are easier IMO.
To clean out the oil, I used a strong solution of Dawn dishwashing liquid an a stiff brush. Don't laugh, it worked like a charm. By the way I did NOT paint my intake manifold red !!
Edek
'87 924S
'91 535i
Old 07-01-2006, 06:17 PM
Edik,
Haha, I was thinking "WTH is a #710 cap?" Had to google it.
I'm still stuck on this one...what is DGV?
I'll try using some dishwashing liquid to clean up the area.
'86 951 blk/blk
Old 07-01-2006, 07:12 PM
onZedge's Avatar
That is a Weber downdraft carburetor model.
Edek
'87 924S
'91 535i
Old 07-01-2006, 07:22 PM
Sorry for so many questions regarding this, but I get pretty worried when I start disconnecting hoses and cords. I hope I don't have a problem remembering what connected to what later on.
Anyways, am I actually removing the oil/air separator in order to change the seals or am I just taking off that top part? I've taken off the cycling valve and I intend to disconnect the hoses underneath it to get to the rest of it. Does that sound like the right procedure?
'86 951 blk/blk
Old 07-01-2006, 08:28 PM
Oh...my...god...I literally spent the last couple hours trying to remove the lower bolt on the AOS from the top without any success. This is ridiculous!
I previously didn't want to take off the downpipe and heat shield, but it's looking more and more tempting.
Has anyone else successfully removed it from the top? I keep reading in previous posts that people have done it, but there's usually no explanation. At this point, I'm practically wondering what exact tools were used to get at it? I've tried everything I've got without any luck!
'86 951 blk/blk
Old 07-03-2006, 12:04 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
710 cap. . . I love that one.
Black Cars Matter
Old 07-03-2006, 06:53 AM
Eldorado's Avatar
on our cars it's a 730 cap.. at least it is on mine.. lol
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 07-03-2006, 07:28 AM
