TNT25169's Avatar
Send a message via AIM to TNT25169
Ball Joint Rebuild Help
I'm rebuilding my ball joints on my control arms and I am trying to remove the clip from the bottom of the ball joint that holds the whole thing together and I can't seem to get it. I have been prying on the clip for a while, does anyone know of a way to do this easily?
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 07-10-2006, 06:40 PM
I ran into the same thing. If the clip is moving, there is no way to wedge it and still put pressure on one side to get another screwdriver under it. I did this awhile ago. I think the best thing is a third hand to hold one end of the clip. Use one small flathead and twist it into the corner created by the clip angled end and the a-arm, then stick a small point or flathead into the gap created when you twist the other flathead. Why o why didn't they put some holes in the ends of that clip?????
Old 07-10-2006, 07:51 PM
That Guy
Techno Duck's Avatar
Dremel with cut off wheel, cut the clip in two. Then hammer it out with a flat tip screw driver.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 07-10-2006, 07:55 PM
SoCal Driver's Avatar
Dremel with a side cutting mill bit. Grind a groove to get behind the clip. This way you can reuse it.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-10-2006, 08:00 PM
TNT25169's Avatar
I'm going to dremel the thing apart tomorrow and I don't need to worry about reusing my clip, new ones are provided with my rebuild kit. Thanks guys.
www.apartabove.com
Old 07-10-2006, 09:44 PM
That Guy
Good luck, this is probably the single most frustrating part of rebuilding the control arms. The 2nd most is compressing the balljoint enough to get the new clip in. It was particuarly hard for because i used the geometry correcting kit, it was tough to find a socket long enough to slip over the balljoint pin.
Jon
Old 07-10-2006, 09:51 PM
arbita1's Avatar
Ever try replacing the front busings on the control arm!
I guess I was lucky. I was able to remove mine with a small jewlers type screwdriver.
Matt.
83 911SC
85.5 944 NA - Sold
Old 07-11-2006, 01:39 PM
That Guy
Matt, i just let Travis at Rennbay deal with it.. heh heh.
Jon
Old 07-11-2006, 02:35 PM
