Can anyone help me find the part number...
I accidently broke off the now-brittle hose coming from the side of the top fo the air oil separator. The hose is crimped onto a metal hose that is screwed into the block just right of the turbo. I wish I could run the PET to find the part, but my laptop only supports 1024 x 768. Anyone know the official name of this thing or the part number for it? I will try getting a picture and posting it tonight.
'86 951 blk/blk -968 M030 Sway Bars with delrin bushings -IceShark headlight kit -Koni Yellow Sport Adjustable struts and shocks -225 lb springs up front Cleaned grounds = happy 944 WTB: 951 black passenger door/fender |
83 944na - Gone but not forgotten. |
Does this help?
![]() The part that I don't understand about this is I had 86 selected and the part numbers on the right say it's for an 87 or 88 only. ...that is if I'm looking at the right hose you were talking about.
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually Last edited by Razorback1980; 08-10-2006 at 07:41 PM.. |
That says thru '87 and the one below it is '88 on.
Nope, I was looking for the hose that comes out of the hole that has the washer labelled 44. After looking at the PDF version of the PET, I think it's the 'vent line' #95112308300. Pelican has it for $165!!
So, here's the thing I was looking for. I'm so pissed that I broke it off because it looks like it's going to take an assload of work to put a new one on there. Plus, I'll probably be paying an arm and a leg to get a new one.
I have a good used one if you're interested?
Sure, I'll take it if it's a decent price. I hope the rubber hose part of it is still plyable. Do you have any idea what's involved in replacing it? I'm afraid of having to take off the turbo down pipe to access it, but I'm guessing that's the way I need to go.
I FINALLY got my air oil separator out without removing the turbo downpipe. So much for that idea, looks like it just got foiled when I broke this hose. I wanted to pull the heat shield with it so that I could put a small hole or notch in it for next time, but the heat shield won't come out!
'86 951 blk/blk -968 M030 Sway Bars with delrin bushings -IceShark headlight kit -Koni Yellow Sport Adjustable struts and shocks -225 lb springs up front Cleaned grounds = happy 944 WTB: 951 black passenger door/fender Last edited by swimmingly; 08-10-2006 at 10:14 PM.. |
Certified Rennwerker
Tom
The PET page you posted is for the 944na S model. He has a 951.
PCA " I've been everywhere, done everything......just can't remember any of it!"
