overheats when I turn on airconditioner
My '84 944 usually runs at the center mark on the temp gauge. but this weekend when I turned on the a/c the needle would climb all the way over to the right side of the gauge, it would take about 5 miles to do so. once I turn the a/c off it stayd between the third and fourth mark all the way home, about 40 mies. granted it was 105 degrees in the shade. It had never ran that hot before, and it usually cooled quicker than that too. both cooling fans were working, and the thermostat is les than a year old, the a/c condensor is clean, The radiator seems to be clean but I got a new one on the way. the only thing left is the waterpump, or am I missing something. any input would be greatfully appreciated.
1992 freightliner
1994 freightliner
1970 dodge challenger r/t se
1994 ford f-150
1984 porsche 944
1991 corvette z07
hopefully a 2008 dodge challenger
Old 08-01-2006, 03:25 PM
Eldorado's Avatar
my uneducated opinion is saying that your car is running a little hot in the first place... half way up the gague is pretty steamy...
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 08-01-2006, 04:01 PM
shikzachaser's Avatar
Make sure the second fan is coming on with the A/C.
84 944 (my favorite all time car)
98 M3 (the wife's)
ML55AMG
03 Eurovan
00 Land Rover Disco II
Old 08-01-2006, 07:24 PM
Someone might be able to verify this but aren't the fans suppose to kick into high when the A/C is turned on? Might check that if this is true.
86 Red 944(sold)
85.5 Red 944(sold)
Old 08-02-2006, 05:49 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
You may also want to bleed the cooling system to make sure it has no air. Is the water pump leaking fluid? If not, then the water pump probably is not the problem. Also check your gauge to make sure it is working properly. Use a thermometer to make sure the gauge is accurate.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 08-02-2006, 07:33 AM
mscromer, you are right, on my 84, the fans automatically kick on when the a/c is switched on (even when the compressor does not kick on). but back to the origional problem, is the radiator cap new? if you do not have good pressure in the system that could be a part of the problem
84 Porsche 944..its why im here
95 Ford F-150
98 Jeep Wrangler TJ
Double 0 Alero. Alright! something from this millenium
Old 08-02-2006, 10:58 AM
Normally the one on the passenger side comes on w/ the A/C. If only the driver's side one is working it can also cause this problem, it happened to me. It's certainly easy to check.
98 M3 (the wife's)
ML55AMG
03 Eurovan
Old 08-02-2006, 01:00 PM
well so far heres what I got: radiator is just over 2 years old, lower temp thermostat and lower temp thermoswitch are 1 year old, both cooling fans work the way they should, one of that fans is a 6 blade the other is a 3 blade. Im getting another 6 blade to replace the 3 blade, the water pump does not leak or sqeel. does anybody know how many degrees each mark on the temp gauge is, because I just bought one of thos guns for checking temperatures. So I'm going to put the car back together start it up and each time the needle gets to a mark on the temp guage I'm going to point the gun at the radiator hose coming off the motor and see what the temp is.
1992 freightliner
1994 freightliner
1994 ford f-150
1984 porsche 944
1991 corvette z07
Old 08-02-2006, 04:16 PM
Eldorado's Avatar
checking the temp of the hose might not give you an accurate reading.. rubber is, after all, an insulator...
Kyle
Old 08-02-2006, 04:19 PM
yeah maybe I should check the elbow at the top of the motor that the radiator hose comes off of.
1992 freightliner
1994 freightliner
1994 ford f-150
1984 porsche 944
1991 corvette z07
Old 08-02-2006, 04:41 PM
Ornery Bastard
Degrees in centigrade, from FR Wilk's site:
http://frwilk.com/early944/misc/watertemp.htm
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 08-02-2006, 04:56 PM
I went to clarks garage and started to check my tempeture sending unit. He tells how to check the later style with 2 prongs, but not the early style with one prong. Does anybody know how, and what the hell is a potentiameter, cant I just use a volt/ ohm meter.
1992 freightliner
1994 freightliner
1994 ford f-150
1984 porsche 944
1991 corvette z07
Old 08-02-2006, 06:31 PM
Mine used to run at the 12:00 position all the time and oscillated from 3/4 back to half on hot days, especially caught in traffic. The car was always properly cared for, and ran like a Swiss Watch to the day I sold it. I owned my 44 over a decade and IMHO the A/C technology of the time caused a noticeble reduction in power in a car that we all get used to having 100% of. The system is inherently weak, even in factory condition, it's not adequate and I believe contributed to overheating in a car whose cooling system shows the inexperience of a company venturing into water pumpers. The large rear hatch window is also a huge factor in the cabin greenhouse effect.
AJF
1998 Glacier White Boxster
1971 Fiat 124 Spyder
1999 Mercury Mountaineer
Old 08-02-2006, 08:27 PM
entertaining the idea
UconnTim97's Avatar
My car runs tip top, and has almost 62K miles, and always runs at 1/2 (12:00) on the temp gauge. Though in this heat lately, it has struggled and runs at 3/4 in traffic with the AC on. It cools back to 1/2 once the car is moving again. You have to remember it is a 20+ year old car....
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 08-02-2006, 10:16 PM
Had same problem-turned out to be the belt was a little loose connecting Aircon and water pump
Old 08-03-2006, 02:37 AM
Paul, your post really confused me....my water pump doesn't run off my Aircon belt....which brings up an interesting point. When was the last time your belts were tensioned?
Tom
Old 08-03-2006, 07:12 AM
Ornery Bastard
None of the 944's drive the water pump off the A/C belt... They all drive it off the back side of the timing belt.
Old 08-03-2006, 08:26 AM
well I went out and bought one of those guns for checking temperatures, when I took my reedings I pointed the laser right on the threads of the sending. according to the diagram on clarks garage. the first tick on the temp gauge is supposed to be 68 degrees celcius, according to my heat check gun it says mine is 54 degrees celcius. the middle mark is supposed to be 89, mine is 64. the third mark is supposed to be 97, mine is 70. Is my temp sending unit screwed, or is it the gauge itself?, I'm thinking it's the sending unit.
1992 freightliner
1994 freightliner
1994 ford f-150
1984 porsche 944
1991 corvette z07
Old 08-04-2006, 12:53 PM
gtroth's Avatar
You might start to think of cleaning some grounds, particularly those on the engine. That lowered the reading ~ half a division on my gauge (note that mine's a late 944). Especially if the gauge jumps when you turn on big loads (headlights, rear defroster, AC...).
Does the needle jump when you turn on the AC or climb slowly?
edit - just reread your original post where it says that it climbs slowly. Still, does it jump at all?
1995 993C4 guards red
1988 944S alpine white
Old 08-06-2006, 05:38 PM
Embarrasing-Should have said Alternator/Aircon belt, which for some odd reason is referred to as a fan belt, even though the fans are electrically driven.
When it was slipping about 1 year ago was last time I checked,as my aircon gave up the ghost . Have been trusting the mechanics that do most of my repairs,as you can tell I mostly tinker.
At that time the belt seemed pretty tight to me as it would take about a half turn. I was worried about tightening it more as I thought it would put too much strain on bearings of the alternator.
Old 08-08-2006, 06:31 AM
