Greasy Member
many944s's Avatar
Unhappy Help please!! '83 944...
Well, I am back in the states and decided to finally finish the '83 build up. I assembled everything, triple checked the timing and tension, built oil pressure then fired her up. After getting all of the air vented from the cooling system, and giving it yet another "once over" look for drips, I decided to take it out for a test drive. The motor purrs like a kitten in park, but only revs up to about 3k when spiking the accelerator. When driving it feels like I need to get out and give it a push to get going? The shift points are smooth, and the ATF levels are fine (with new ATF).
Any ideas? Unfortunately this needs to be my daily driver for a while as it looks like my Mustang is getting ready to buy the farm.
The idle RPM is at 980, and the throttle body "clicks" where it should when advancing the throttle by hand. I have worked on countless MT 944s but have never worked on an AT model. I honestly haven't seen this problem before.
Thanks in advance guys!
Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 08-23-2006, 03:55 PM
SoCal Driver's Avatar
AAMCO. Same trans as the VW automatics.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-23-2006, 04:28 PM
Greasy Member
many944s's Avatar
Thanks SOCAL, so you think it's the tranny? I can't even get the engine to rev in park like I can my MT?
Old 08-23-2006, 05:28 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
It doesn't sound like a transmission. If it does it with the transmission in Park, then the transmission shouldn't have anything to do with it. It sounds like it's starving for gas or the timing isn't being advanced properly by the computer. I've heard that the injector wires sometimes have dirty connectors which would make the voltage to the injectors incorrect and the air/fuel ratio would be off. I would also check the TPS and see if it is working properly.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 08-23-2006, 06:53 PM
Greasy Member
many944s's Avatar
Thanks Tom. Well, I just spent another couple hours in the garage working on the beast. All the injectors and the harness are new, I noided each connector and used my pulse injection tester to test each of the injectors (just to be sure), all turned out to be ok. I also checked the "accel" pont on the TPS, and it responds properly.
I actually thought ahead when I had the motor torn down and marked the TDC line on the flywheel with white paint, along with the timing mark on the cam pully. Using a timing light, I can see that the timing is advancing properly on acceleration...
I swear, if I had any hair, I would be pulling it out !
I'll keep you all posted!
Nick
Old 08-23-2006, 08:01 PM
I am just guessing at this point but you might try unplugging the O2 sensor. I think that will richen the mixture by default and see what the effect is.
Tom
Old 08-23-2006, 10:52 PM
