-   -   DME temp sensors ?? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/301229-dme-temp-sensors.html)
924Sman 08-29-2006 06:30 AM
DME temp sensors ??
I need to know if I did this test correctly. Using my ohmeter on the blue sensor on the block I connected to terminal 13 at the sensor and on the plug. Tried both posts on the plug and sender and my meter reads .0L. No matter what I connect to no reading at all. Book says to check at the DME plug but I used the plug at the sender.
Did I do this right and have a bad DME temp sensor?
tia!
Dal
ae1969 08-29-2006 07:08 AM
If you have the meter connected at both posts on the sender and it reads .0L
Its toast
924Sman 08-29-2006 07:33 AM
One to ground the other to the terminal post. Checked each terminal on the plug and the sensor.
Dal
