-   -   Relay problem? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/303943-relay-problem.html)
cava7 09-12-2006 09:03 AM
Relay problem?
I have an 87, non turbo 944, I changed the clock yesterday and when I plugged in the cigarette lighter I had a short circuit, fuse was blown, (#11)replaced it blew it again, so I unplugged it, checked the connectors, they seemed to be ok, plugged it again, it didn't blew the fuse (#11), BUT, I don't have lights inside, headlights motor doesn't work, can't open windows, A/C doesn't work, cigarette lighter either, etc, ALL the fuses are ok, I image it must be a relay problem, but wich one? I read somewhere that it could be the X relay, now, wich one is this and where is it located?, I would really appreciate your help with this..., thanks, Carlos
SoCal Driver 09-12-2006 09:44 AM
Clean and check ALL the connections at the positive terminal at the battery. Could also be the fuse box buss for battery positive voltage. Is there an aftermarket alarm or a high end stereo system in the car? Could have it's power taken off of the bottom of the fuse/relay box on the same buss.
The items that have failed all come off of the same buss.
