scintaar's Avatar
Unhappy Timing belt snap
hi... My timimg belt snapped at just over idle speed... what's the possibilty there's no serious damage?
Just in case the outlook's bad... does anyone on here know of a good place to pick up a 2.5 16v engine in Britain?
... you don't need eyes to see, you need vision!
95 Mitsubishi FTO V6 MIVEC
88 944s
92 BMW 320i - E36
88 BMW 320i - E30
Old 09-24-2006, 01:06 AM
Outlook not bad, just bent valves, guaranteed.
Spend about $1500 USD (about 700 GBP) and have the valves replaced, new head gasket, and bob's your uncle.
Not worth replacing the motor over...
Cheerio!
Good luck, George Beuselinck
Old 09-24-2006, 04:10 AM
SoCal Driver's Avatar
Well since it is a 16 valve engine I would pull the valve cover and inspect the cross over chain, cam teeth and tensioner.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 09-24-2006, 07:56 AM
