-   -   944S2MAX beta tester needed (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/310853-944s2max-beta-tester-needed.html)
rberry951 10-21-2006 11:02 AM
Hello,
The 944S2MAX chip is ready for beta testing. You will need access to a dyno. The tester pays for dyno runs so you will need access to a cheap or free dyno as it may take up to three trips to the dyno to complete the production product.
You will test the 944S2MAX chip against stock chips and provide feedback as detailed performance descriptions and dyno charts for further tuning.
You will receive a free chip for your S2, and if you own vehicles we make other chips for such as the 944S or 944Turbo you will receive free chips for those as well, up to three cars.
If interested please PM me or drop me an email at:
Russell@maxhpkit.com
Thanks!
Regards,
Russell
Mike B 10-23-2006 03:58 PM
ttt
rberry951 10-23-2006 04:05 PM
I'm afraid I don't know what 'ttt' means...
ae1969 10-23-2006 04:22 PM
'bump to the top'
in Canadian....... :D
rberry951 10-23-2006 04:29 PM
AH!
Eh?
lateapex911 10-23-2006 09:03 PM
Whats the value of the chip?
Will you be doing anychips for 944S2s that will be raced? (I will be running a 944S2 with SCCA in the Improved Touring ITR class, so that would be a .5 bump in compression, port matching, internal parts optimization, header and free exhaust)
rberry951 10-23-2006 09:12 PM
Once the baseline production chip ships I'll be open to modified chips. Actually a race chip is 'easier' to produce because I don't have to worry the car running 89-91 octane gas and blowing a head gasket or burning valves and such. The groundwork for the S2 development is already done, and I have chips ready to test, just need a guinea pig. If I can find one locally it would be ideal as development would proceed much more quickly. It's time consuming to tune remotely. But by the same token it actually allows me to tune better for drivability, as you can't really address that on a dyno. So my tuning is a combination of driver input and dyno numbers and data logs.
Are there guidelines for chipped cars in SCCA? As far as how far you can go with them, or is it just a matter of tuner capability?
Regards,
Russell
lateapex911 10-23-2006 09:37 PM
The current rule allows any chip that fits the box...actually, if you can fit any engine management system in the stock enclosure, you can do so. So we see some Motecs actually stuffed into cases at exorbinant prices.
(I am on the rules commitee) And it is currently being discussed. One option is to allow any sytem, and throw out the "in the box" requirement.
So, no, anything goes with chips, LOL>
Assume race gas, and slightly greater compression, and full on header/exhaust systems. Goals are as always, greater power, and broader tq curve. !-3K rpm respnse isn't terribly important.
And as many revs as the mechanical constraints of the engine will allow..
where are you located? What limitations are you faced with when dealing with the Porsche system?
rberry951 10-23-2006 10:47 PM
I'm located about 20 miles SW of Albany, NY near the Catskills. I'm in the sticks, nothing out here but deer, coyotes, bears, etc..
My only limitation right now is access to cars and tuning equipment like dynos. But like I said I just found a dyna-pak fairly close by and am going to be working with some local shops soon to move things along a little better. I have a knack for determining the engine characteristics, reading stock Porsche code and improving upon it. Like I said in production chips I focus on the partial throttle maps first because that's where normal cars spend 90% of the their time. Then I broaden the overall power band and usually end up squeezing a bit more HP out of it. On turbo cars it's a whole different ballgame, all kinds of different turbos, mods, injectors, etc. Tuning for mechanical changes like heads, exhaust, intake characteristics, etc. is actually easier. Especially when a lot of turbo vendors won't disclose the actual flow characteristics of their products. Obviously they don't want anyone to tune their product better than they can.
I just want to make cars go faster. If I make some money along the way great, if not, I'm making cars go faster and I'm happy!
Regards,
Russell
jgp0rsche 10-24-2006 04:26 AM
Someone help Russell out. I have been the guinea pig for the 944SMAX chip. He is GREAT to work with, plus he can do wonders for your car.
Brando 10-24-2006 10:25 AM
Have a regular 944 chip? 1987-on?
There's a local dyno place I could do some runs on.
rberry951 10-24-2006 10:31 AM
YES! The NA chip is ready to begin testing as well. PM me your address and I'll get a chip right out to you!
Regards,
Russell
Brando 10-24-2006 10:45 AM
E-mail't! :D
maddydaddy 10-24-2006 06:26 PM
Well, I have a stock (engine wise) 89 944 S2 that I put an autothority chip in. I would be willing to help you. If it matters, I still have the original chip. I could put the original chip in, get dyno'ed, then your chip and compare. I have already dyno'ed with the autothority chip, so it would be cool to have all 3 chips compared on the same car and dyno.
James Reeser
gotcabinfever@hotmail.com
89 944 S2
rberry951 10-24-2006 06:30 PM
James Reeser
89 944 S2
Hi James,
I found a beta tester for the S2 today actually, and another for the 85.5-88NA. Now all I really need is someone with a late 2.7L NA. But I will also send you an email shortly.
Regards,
Russell
rberry951 10-24-2006 11:25 PM
UPDATE!
Okay now I have 86-88NA testers and S2 testers, the only thing I need now is a late 2.7L NA tester.
Any takers?
Regards,
Russell
