-   -   Can't find TDC mark on the "S" (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/313976-cant-find-tdc-mark-s.html)
Panzer909 11-08-2006 10:51 AM
Hi guys,
Doing the timing belt job on the S. I'm having a heck of a time finding the TDC mark near the clutch housing. The info on Clarks Garage doesn't seem to help either. I don't know if there's a difference for 16v engines or not, but can someone point me in the right direction? A pic or two would be ideal. Thanks.SmileWavy
87944turbo 11-08-2006 11:21 AM
I think this is what you are talking about.
http://forums.pelicanparts.com/uploa...1163013643.jpg
Sigurd 11-08-2006 11:50 AM
I am also in the middle of a belt, rollers, and water pump change on my S myself. I found the OT mark on the flywheel more accurate. I had a friend looking through the square hole in the bell housing with a strong flash light while I was turning the engine, 24 mm socket. The hole is on top of the bellhousing a little to the left.
944 Ecology 11-08-2006 11:55 AM
no notch on the bottom of the flywheel on the 16 valve engines, only on the later 8v engines.
JivenJim 11-08-2006 12:25 PM
Not sure if the S is same as these pictures from the 968.
I have a aftermarket flywheel with a sharpie mark I put on and reference to the second page marker by flywheel sensor.
http://forums.pelicanparts.com/uploa...1163017446.jpg http://forums.pelicanparts.com/uploa...1163017466.jpg
bazar01 11-08-2006 03:35 PM
Here is what you are looking for.
http://forums.pelicanparts.com/uploa...1163028880.jpg
hpaulb 11-09-2006 12:45 PM
You need both hands in there. On for the light and the other to hold thinks back. Then cock your head till it hurts. Strain your eyes till you find it then you can say "OH Ya there's that stupid thing."
Panzer909 11-09-2006 01:05 PM
Thanks guys but I'm still a little lost. bazar01, with the brake booser blacked out in the pic its hard to get a reference point. Were you looking straight up when taking that?
Anyways, details details. Maybe its not worth the trouble. I doubt lining this up will matter when I put it all together, right?;)
bazar01 11-09-2006 01:26 PM
Nope, looking from the top of the engine down to the bell housing.
I lay down on my belly on the driver side fender with the hood up looking from the space between the brake booster and the reference sensor plug, down to the bellhousing close to the grounding cables beside the reference sensor mount in the bellhousing hole.
Look sideways from the windshield side down to bellhousing. Take it easy and don't break your neck. It hurts especially on the back. :D
When putting everything back, it matters because the flywheel is locked and your only reference is the camshaft pulley mark.
