Mein Gott!
Panzer909's Avatar
Can't find TDC mark on the "S"
Hi guys,
Doing the timing belt job on the S. I'm having a heck of a time finding the TDC mark near the clutch housing. The info on Clarks Garage doesn't seem to help either. I don't know if there's a difference for 16v engines or not, but can someone point me in the right direction? A pic or two would be ideal. Thanks.
Johnny
1987 944S
1984 944 (R.I.P.)
1972 Triumph TR6 - 100% trouble free between breakdowns
2003 BMW 325xi
Old 11-08-2006, 10:51 AM
I think this is what you are talking about.
Old 11-08-2006, 11:21 AM
Sigurd's Avatar
I am also in the middle of a belt, rollers, and water pump change on my S myself. I found the OT mark on the flywheel more accurate. I had a friend looking through the square hole in the bell housing with a strong flash light while I was turning the engine, 24 mm socket. The hole is on top of the bellhousing a little to the left.
Sigurd
73.5T 3.2SS EFI
X87 944S 3.0
Old 11-08-2006, 11:50 AM
no notch on the bottom of the flywheel on the 16 valve engines, only on the later 8v engines.
Good luck, George Beuselinck
Old 11-08-2006, 11:55 AM
Not sure if the S is same as these pictures from the 968.
I have a aftermarket flywheel with a sharpie mark I put on and reference to the second page marker by flywheel sensor.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 11-08-2006, 12:25 PM
Here is what you are looking for.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 11-08-2006, 03:35 PM
Send a message via AIM to hpaulb
You need both hands in there. On for the light and the other to hold thinks back. Then cock your head till it hurts. Strain your eyes till you find it then you can say "OH Ya there's that stupid thing."
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 11-09-2006, 12:45 PM
Mein Gott!
Panzer909's Avatar
Thanks guys but I'm still a little lost. bazar01, with the brake booser blacked out in the pic its hard to get a reference point. Were you looking straight up when taking that?
Anyways, details details. Maybe its not worth the trouble. I doubt lining this up will matter when I put it all together, right?
Johnny
1987 944S
1984 944 (R.I.P.)
2003 BMW 325xi
Old 11-09-2006, 01:05 PM
Nope, looking from the top of the engine down to the bell housing.
I lay down on my belly on the driver side fender with the hood up looking from the space between the brake booster and the reference sensor plug, down to the bellhousing close to the grounding cables beside the reference sensor mount in the bellhousing hole.
Look sideways from the windshield side down to bellhousing. Take it easy and don't break your neck. It hurts especially on the back.
When putting everything back, it matters because the flywheel is locked and your only reference is the camshaft pulley mark.
Old 11-09-2006, 01:26 PM
