lateapex911's Avatar
OK, here's an easy one: Water leakage
My 944S@ has developed a bit of a "water feature" in it's drivers side footwell. Surf has been breaking nicely over the clutch pedal, LOL
In a quick look, I found water collecting in the area around the electrical center/fusebox, and the battery on the other side after rains. Moving the car eventually empties the standing water up top, but the floor and carpet remains soaked. And with more rain coming...
Can anyone point me in th right direction? Perhaps a link to a solution, or an explanation? I am thinking that some drain aint draining.
What say the experts?
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 11-14-2006, 01:50 PM
AFJuvat's Avatar
Your have a water drain on each side - closest to the fender. It looks like a little hump in the metal. Make sure that they aren't full of crap (leaves and pine needles love to get stuck in there.
After making sure that they are clean, take a hose and fill up the area and check under the dashboard for leaks. Corrrosion or cracked seams can let water in as well.
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 11-14-2006, 02:06 PM
Not Special
I'm troubleshooting some of the same stuff - except mine is in the trunk. Definately check the drains for leaves, that was largely my problem.
Current: 1989 Porsche 944 S2 - Baltic Blue/Linen
Former: 1985/1 Porsche 944 - Graphite/Black
Old 11-14-2006, 02:42 PM
Eldorado's Avatar
check the seals around your power antenna (if you have one)... i've heard of water leaking down along the wire of the antenna and dripping into the footwell.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 11-14-2006, 02:59 PM
Thanks guys! I'm on it tonight or tomorrow.
Wipeout, I had the same issues, A PO had cheaped out with the old taillight gaskets and used silicone...and it was applied poorly. It lets a LOT of water in when parked at certain angles. opening the drains is mandatory!
Old 11-14-2006, 04:37 PM
Not Special
My problem is the driver side back seat - the seat pad itself is soaked, but everything around it is dry. It's as if someone took a bucket and emptied it on the seat. I think I have it figured out but I'm checkin' still - heavy rain expected tomorrow!
< /end threadjack>
Old 11-14-2006, 06:23 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Wipeout...mine does this too. The window frame on mine had pulled away from the glass and the rain was running in around the window frame. If you look you will probably be able to see the edge of the glass which should be inside the window frame. Do a search, you will find a thread I started on how to fix it. Tim Hancock helped me figure out how to fix it.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 11-14-2006, 06:59 PM
Eldorado's Avatar
I get a puddle on my driver's side back seat.. comes from a drip-drip-drip from the corner of the sunroof.
Kyle
Old 11-14-2006, 07:01 PM
EMBPilot's Avatar
Send a message via AIM to EMBPilot Send a message via Yahoo to EMBPilot
if the seal from the rear deck hatch pulls from the body a little bit in the top corners, water will drop right about on the top outside of the pax or drivers side rear seat.
if your looking for a battery compartment fix check this thread ideas for a small hole in battery compartment
1995 993 C2
Old 11-14-2006, 08:15 PM
Not Special
Thanks guys. I'll bet it'll get a little wetter tomorrow...
It doesn't seem to be the sunroof, and it doesn't seem like the rear hatch because if I put the seat back down (to give me more storage space) that carpet does not get wet.
What I really need to do is get someone to blast it with a hose while I sit inside. Sounds like a weekend project to me!
Old 11-14-2006, 09:19 PM
