-   -   Voltage and Temp gauge are sparatic? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/315246-voltage-temp-gauge-sparatic.html)
pozican 11-14-2006 09:58 PM
They bounce when I press the brakes...
The batt gauge reads incredible low, and the temp gauge sometimes reads about right, sometimes really really high (but the overheat warning doesnt come on, and I'm *positive* it wasn't overheating)
When I shut the car off, the temp gauge pegs itself on the top peg.
Whiskey tango hotel?
Thanks guys,
-Alex
Eldorado 11-14-2006 10:28 PM
Re: Voltage and Temp gauge are sparatic?
yes please!
pozican 11-15-2006 09:27 AM
I think my temp gauge is shorting and I think the battery has a bad ground, maybe both on both, maybe the problems or gauges are switched, either way, anyone know where the location of the ground and the pickup are for the battery and the temp gauge?
Thanks,
-Alex
Razorback1980 11-15-2006 01:51 PM
There are seven (I think) ground places on the car and they all need to be cleaned periodically. Do a search here and you will find a detailed diagram of all of them. If you can't find it, let me know and I'll look for you. Doesn't sound like a short to me...sounds like more of a ground issue. A short will usually blow a fuse.
Techno Duck 11-15-2006 01:56 PM
http://img.photobucket.com/albums/v1...42_grounds.jpg
There are a few under the dash aswell not listed in this picture.
JivenJim 11-15-2006 04:42 PM
Check Clarks guide elect-19 (for Gauge Trouble shooting)
I think your ground is either on the firewall up under dash, or under fuse panel. (you have to remove from bracket to check)
pozican 11-15-2006 05:43 PM
Under the dash like stick my head under, or under the dash like, pull the gauges under? ( **Shudder** )
