Send a message via Yahoo to nickeleye
1986 (944) turns over but doesn't start
1986 Porsche 944, i love the little bugger but its being a pain in my ass. it turns over but wont start... a diagnostic was run on the computer, finding that the speed sensor/s is bad. And sure enough one appeared to have wire damage, and I've replaced it. But still nothing, i no the fuel pump is working, but its not sparking. And I don't think fuel injectors are firing. Any ideas, pointers, or suggestions would be a great help. Thanks for reading.
-andrew
Old 11-18-2006, 03:46 PM
ERAU944's Avatar
Send a message via AIM to ERAU944
the speed/ref sensors may have been switched... try switching the wires?
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 11-18-2006, 03:53 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Do a search from a guy called SoCal Driver and search for "five minute test". That will give you detailed instruction on how to find the problem. You are not the first to see this. Also check out clarks-garage.com a lot of good information there.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 11-18-2006, 11:15 PM
I thought the wires may have been switched as well, but changing them made little difference. While i was in the shop i had a owner of a 911 explain to me that the reference sensors sit on a bracket which can be adjusted. Additionally he explained that when the reference sensors are working that the tachometer will jump, when the engine is turned over. Which when the bracket (holding the reference sensors) is in certain positions it does. Is there anyway to tell (without actually starting the car) if the sensors are switched?
-andrew
Old 11-19-2006, 11:50 AM
I read the article in clarksgarage.com on "Speed and Reference Sensors", i have a few questions... what happens if you don't disconnect the negative battery terminal? and The speed sensor and the reference sensor both do different things right? But are they the same piece of hardware? Would they be interchangeable?
-andrew
Old 11-19-2006, 12:17 PM
ERAU944's Avatar
they are interchangeable, however their position when plugged into the harness is not - i.e. the leads get different signals from different portions of the flywheel, and go to different parts of the computer. the ref. references TDC i believe, and speed counts teeth on the flywheel relative to time if i am not mistaken.
Old 11-19-2006, 12:22 PM
cool thanks to all i am gonna work on it tonight and tomorrow after i get of work, we'll see how it turns out. i also heard a tip from a friend, not sure if works but i'm gonna try it: disconnect both battery terminals and connect them (the wires), leave it sit for twenty minute. it resets everything on the car, which makes sense if you consider it.
-andrew
Old 11-19-2006, 02:25 PM
Did you check/replace DME sensor?
86 Ford Bronco
87 Porsche 924S
98 BMW 318ti
01 VW Turbo Bug
Old 11-20-2006, 05:20 PM
Disconnecting the battery will have no effect on this car. That is to reset the computer on an ODB II computer placed in cars from 96 forward. Go through the diagnostic procedure...it takes five minutes and will reveal what the problem is. Probably will be the DME relay but you need to test to be sure.
Tom
Old 11-20-2006, 09:26 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
This is in no way a rational replacement for sound trouble shooting techniques, but it worked for me:
Go down to where the the sensors bolt into the housing (probably 10mm hex but could be allen head 5-6mm) and swap em. Then, of course, swap the plugs. I doesn't hurt to chant "A pox on Bosch sensors! Cursed is your wispy copper coils!". Well, it doesn't hurt if no one overhears you.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 11-21-2006, 12:50 AM
clarksgarage.com is badass, it helped alot, but im still not set. i have changed both of the sensors (speed and reference) im afairly certain there a no issues with the fuel pump. i released pressure from the fuel line tightened the bolt, turned the engine, and there was pressure in the line again. I finally got it running but it has to turn over quite a few times. i thank everyone for the advice but i'm still having trouble. not sure why. the engine also sounds like it running harder also running harder than it was... any ideas?
-andrew
Old 11-21-2006, 05:18 PM
any ideas for selling a 1986 (944) porsche in san antonio? it needs alot work (obviously). i have to leave for mississippi next week and i cant drive something this unreliable down there. thanks
-andrew
Old 11-21-2006, 08:37 PM
Sure...drop it off in Houston along the way and I'll be glad to drive it around for you until you return!
Tom
Old 11-21-2006, 11:56 PM
