Mein Gott!
Panzer909's Avatar
Exclamation Waterpump install problem
So I decide to do a little wrenching in the unheated garage tonight and attempt to install my brand spanking new H2O pump.....
I accidentally drop the pump under the car while trying to fit it on the front end and this chips off a small part of the impeller (which extends from roughly 12 'o clock to 2 'o clock if you're imagining the impeller as a watch face). Okay, this sucks but I figure it should still be okay to install.
So I bolt it on and the outside pulley would now only move about 10 degrees in either direction.
I'm concluding that the chipped impeller no longer makes it perfectly circular and the rough edge is getting "hung up" on a part of the water passage routing on the block right behind it. Nice. So before I start bringing out the sandpaper and grinding on something, has anyone ever had this happen to them and was there an ultimate solution (rather than calling Paragon Products to inquire on their return policy on a purchase over three months ago
Johnny
1987 944S
1984 944 (R.I.P.)
1972 Triumph TR6 - 100% trouble free between breakdowns
2003 BMW 325xi
Old 12-04-2006, 06:10 PM
SoCal Driver's Avatar
Bent the shaft.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 12-04-2006, 06:23 PM
That Guy
Techno Duck's Avatar
I would get a new pump. It will be an expensive mistake, but it prevents you from making an even more expensive and PITA mistake a few minutes into running the engine for the first time.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 12-04-2006, 07:24 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Now that is quite the drop.........
Ouch
Get another one...
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 12-04-2006, 08:07 PM
JB Weld can do so mighty fine recovery's.
The Flow Does Not need to be prefect... Just close. and clear of sides.
former aerospace engineer.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 12-04-2006, 08:28 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
I'm with Alex, Hugh and Jon...not an area to play with. If it wobbles or comes apart while driving, then there could be considerable damage to your engine. If it were something that didn't hurt your engine if it broke further like maybe an exhaust manifold that was cracked, you could experiment and try to repair it, but not something this important. I would replace it. I know that had to hurt and I'm sorry that happened.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 12-04-2006, 09:26 PM
Mein Gott!
Panzer909's Avatar
Yeah. The chipped part is the least of my worries. Even if I did manage to get the clearance there would still be an ever-so-fine impeller wobble and this doesn't really endorse peace of mind. By spinning it by hand it sounds completely silent and the bend is so fine you cannot even see it. Its the 1cm scrape on the outer edge that says there is a problem.
Jeez. I dunno. I'm going on a week long vacation tomorrow so I'll just put it away and think about it for now. Decisions decisions..........
Johnny
1987 944S
1984 944 (R.I.P.)
2003 BMW 325xi
Old 12-05-2006, 08:31 AM
That Guy
Remeber it may feel fine by hand, but spinning at 5000rpms how do you think that wobble is going to feel?
Jon
Old 12-05-2006, 09:16 AM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
That is 5K RPM crank speed, There may be a different ratio crank to WP. No, with that engine I would not fool with a bent shaft, JB weld could probably get you by if it was a small chip, for a large chip take it to a good welder and then file or machine the mating surface.
See if anyone in your area rebuilds water pumps. For a good rebuild the shaft and seals are replaced anyway all you need is a good body and impeller. I don't know if this WP has a common size shaft and seal, but I wouldn't be surprised either way. Sorry for your luck.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 12-05-2006, 09:33 AM
