85.5 944 dash gauges don't work, fuse?
Hey guys,
A guy with a 85.5 944 is asking me about his 944. He says the dash gauges don't work, but the dash lite comes on.
Is this on one fuse?
Any idea's are great thanks much!
89 Porsche 944
Owner: AutoFreeFinders.com Online Auto Mall
Old 01-03-2007, 04:08 PM
Gon fix it with me hammer
svandamme's Avatar
need more info
no gauges work at all?
some work? if so , which ones do not work which do?
fuses are easy , you can visually see if they are toast or not
just check the fusebox.
Stijn Vandamme
BIMDIESELBMW116D2019
Old 01-08-2007, 08:33 AM
Thanks for the reply.
I haven't seen it myself, he was just asking me.
From what he says, no gauges work. But the dash lights do work.
89 Porsche 944
Old 01-08-2007, 09:18 AM
svandamme's Avatar
i'll have to leave it to others, don't know a type 2 dash setup to much...
i'ed check the fuse box cover... see if any of em are dash related, and check if any of em are busted
Stijn Vandamme
Old 01-08-2007, 09:34 AM
Ok, I will pass it on to him.
Thanks much.
89 Porsche 944
Old 01-08-2007, 09:43 AM
I would suggest:
First Disconnect battery.
Clean the contacts on the Three Ribbon Cables with an eraser and Some contact cleaner. Remove Cluster first. Clarks' garage (pdf-manual/elect-07.pdf )
There are some plastic lug nuts that are suppose to be metal jumpers. remove them and sand contacts. (never done that but heard it can help.)
Check / clean Central electric ground point under fuse/relay panel. Just follow all the big Brown wires to chassis. and yep you gotta remove the Panel bolts to find this.
Hope one of those works for you.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 01-08-2007, 12:42 PM
Thanks Jim!
89 Porsche 944
Old 01-08-2007, 01:20 PM
I have an 85/2 944 that did the same thing. replace the ignition relay (G-2) and the X-relay (G-14) that worked for me.
1985/2 - 944 Good ten foot car
Old 01-08-2007, 03:27 PM
Thanks Steve...
Good stuff.
89 Porsche 944
Old 01-08-2007, 03:32 PM
