Easier way to connect vacuum line under intake?
There is a vacuum line that goes under the intercooler to intake pipe that is essentially on the intake, and it is rediculously difficult to get a vacuum line onto it.
Is there an easier way? :confused: Thanks! -poz |
if its the one i am thinking of, the answer is no. pictures?
Small magical elves. Seriously..... Either that or gumby. Unfortunatly in the real world, you may have to loosen or remove the intake, attach it and rebolt the intake. Someone may have found a better way.
This is the one under the throttle body at the front, right? Hook everything else up, sit the intake in place but don't bolt it down yet. Lift slightly, hook up the vacuum line and then re-seat the intake and bolt everything down. It's not that hard. The hardest thing is that infernal 10mm bolt holding the oil dipstick in place.
Thanks a lot!
Kinda lame they HAD to put it there! I found someone with small hands to do it. We all know what small hands mean... ok, bad joke. Thanks guys :) |
small hands = better porsche mechanic ;)
| All times are GMT -8. The time now is 02:55 AM. |
