acooper187's Avatar
preventing engine fire
I been seeing a lot of 944's either being stripped out or trying to be sold after a engine fire. I would hate to see this happen to mine. What is the best way to prevent this from happening?
'87 944 - Gaurds Red
Old 02-06-2007, 05:59 PM
SoCal Driver's Avatar
Replace all of the seals for the injectors. Replace the hoses between the steel lines and the fuel rail with the proper ones; high pressure fittings as necessary. Don't use a fuel rail that has a crack. Make sure the hose are properly supported and do not vibrate and cause the fuel rail to crack.
Due diligence.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-06-2007, 06:06 PM
thekidd's Avatar
Send a message via AIM to thekidd
hers another one HOT porsche
pics steve
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 02-06-2007, 06:10 PM
EMBPilot's Avatar
Send a message via AIM to EMBPilot Send a message via Yahoo to EMBPilot
and be ready to open up a whole can of worms!
1995 993 C2
Old 02-06-2007, 07:17 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
A friend of mine had his go up because oil was leaking from the plate on the back of the cam tower and he said by the time he got it stopped after noticing the smoke, the flames were already there. But knowing him, the smoke was probably there for a while.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 02-06-2007, 09:26 PM
thekidd's Avatar
thats no good to hear because I was leaking oil on my headers from my rear gasket and there was smoke sometimes.But i just replaced my rear cam housing seal where the drip was, and now i cant fit the lowere nut back in the hole? But not a lot of oil is under the seal.
Old 02-06-2007, 11:25 PM
Greasy Member
many944s's Avatar
Besides regular maint, I recommend installing a fire suppression system. At the first sign of problems, you can pull the handle and fill the engine compartment with halon.
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 02-07-2007, 08:00 AM
