Graduated User
conkeytonk's Avatar
Cat guts
Gut the catalytic converter, essentially creating a resonator, replace the cat-back network with an OE and replace all gaskets/hangars as a temporary measure while considering a 3-inch, all-the-way stainless, sport exhaust system (or just give the NA to my daughter and get myself a 951)? Opening the rear has done so much for the Sciroccos. Good idea?
Randy
1977 Scirocco Rebuilt 1.7L Stock Grey (Totaled)
1979 Scirocco Built 2.0L Stroaker Blue (Pilfered)
1979 Scirocco Built 1.8L Rust Bucket Tan (See ‘ya)
1982 Scirocco Rebuilt 1.7L Garage Kept Gold Daily Driver
1987 944 NA Rebuilding 2.5L One Female Owner Grey Weekender
Cruising to a conkeytonk in my Scirocco on steroids
Old 02-14-2007, 06:05 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
There is divided opinion on this topic. Some people say it opens things up, some say that the change in backpressure robs power at certain RPM. My guess is that the torque curve changes, and whether or not it is an improvement depends on the owner's driving style.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 02-14-2007, 06:47 PM
EMBPilot's Avatar
Send a message via AIM to EMBPilot Send a message via Yahoo to EMBPilot
My engine is stock so this will give you an idea of where im coming from. and im no 944 expert, heck i dont even race the car or auto cross it but heres my take.
when i bought my car it has some generic 'free flow' $hit can muffler on it, along with a cat delete pipe.
i replaced the muffler with a stock cat back system, i took the car and had a cat welded into the test pipe. i dont recall the size, but it was slightly larger than stock, i want to say 2.25 or 2.5???? not sure... whatever the case it was the size that was matched to the cat delete pipe.
I am 100% sure, the car is more responsive and runs better after putting the very close to stock system back. as well as sounding much better. however, there was a significant decrease in gas mileage. went from 30+ on the highway into the upper to mid twenties.
1995 993 C2
Old 02-14-2007, 07:34 PM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
Do not, whatever you do, gut the cat.
I gutted my cat.
It sounded like complete and total ass-can.
If you must, then weld in a straight pipe - the empty cat will make horrendous noises.
To tell you how bad it sounds, I drove the car once. Then cut the cat off the exhaust and used PepBoys exhaust clamps to clamp on a cheap piece of pipe. It leaks a little at both ends. It still sounds WAY better than a gutted cat.
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 02-14-2007, 07:55 PM
EMBPilot's Avatar
^^^ X2, agreed! before i had the new cat installed into the pipe, i just had the stock muffler bolted up with the full test pipe. the car sounded better but the cat delete pipe resonated BIG TIME and the car STILL had a can sound to it. half as bad as with the muffler but it sounded awful. big time resonation.
once the cat was installed into the pipe, all the resonations disappeared and the car sounded AND ran great.
1995 993 C2
Old 02-14-2007, 08:01 PM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
Converter test pipe would be the way 2 go. If you do take off the Cat. give it a nice hot drive first, after cool down remove it. then wrap and seal the ends to keep the moisture out.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 02-14-2007, 08:49 PM
Back from Beyond
Getting rid of the cat and keeping the stock muffler worked well for me. Cat was just replaced with tubing same diameter as the rest of the system.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 02-14-2007, 10:16 PM
Graduated User
conkeytonk's Avatar
Lots of useful opinion here guys…thanks. I’m guessing gutting the cat would create too much resonation so is not a good idea; a straight pipe in its place is an option, not really necessary but will increase fuel mileage; go with an OE cat back system (hey Kevin, is this system stainless?). At this point I’m contemplating weather to leave the cat or replace with a straight pipe. Can somebody overwhelmingly convince me? Of course leaving the cat is less expensive, but at 20 years old, is it still functional? Another question, will any of these modifications affect readings the oxygen sensor sends to the DME (computer)? You guys are a great recourse and I make most decisions about my project based on what comes back, thanks again.
Randy
Old 02-15-2007, 05:04 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
O2 sensor should read about the same as it reads the exhaust ahead of the cat IIRC. Some systems use two O2 sensors one before and one after but I haven't seen or read about any 944 that does that.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 02-15-2007, 07:23 AM
Cars & Coffee Killer
legion's Avatar
I gutted the cat on my 951. It virtually eliminated turbo lag. I have no idea what it would do for an NA, but it was a huge improvement for me.
5 liters of VVT fury now
-Chris
Old 02-15-2007, 07:42 AM
meister member
speedracing944's Avatar
I kept my cat intact but opened the muffler, cut out the insides, welded in the straight pipe, welded the muffler back together and repainted it. I like the sound and I think I got a little more power out of it. The guts of the muffler appeared to be pretty restrictive.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 02-15-2007, 08:17 AM
