tnporsche's Avatar
odometer gear
Does the 1988 automatic have the plastic gear that strips often?
My speedo works ok but no odometer.
I wanted to order it before I pull out everything. ( I could not find it listed in Pelican )
Anybody got a link to the gear?
Also any tips on pulling the horn button off to get to the s wheel nut? I have pulled on it to the point of all most breaking!
Lowell
1988 944 Red Project car (Now daily driver, Daughter's to school ride)
1983 944 Grey NEW Project car
http://www.pelicanparts.com/gallery/tnporsche
Old 02-07-2007, 03:10 PM
Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
I assume the speedo is the same as a stickshift; if so, then yes. I don't believe you can buy the gear separately through normal channels but I got one from
http://www.odometergears.com/
and it has been working fine for the past three years or so.
nate
1988 944... and a bunch of other cars
Old 02-07-2007, 03:14 PM
Redline Racer
HondaDustR's Avatar
rennbay also has them.
http://www.rennbay.com/odometer-gears-c-32.html?osCsid=4bc0e093236bc646d9d228c47cb6e728
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 02-07-2007, 04:01 PM
tnporsche's Avatar
Thanks for the links,
(other than, get a bigger hammer) LOL
Lowell
Old 02-08-2007, 07:28 AM
Redline Racer
HondaDustR's Avatar
What steering wheel do you have?
Old 02-08-2007, 08:55 AM
"the book" says you have to pull the wheel to get the cluster out, but you really don't if you are careful. It is tight, but it will come out.
nate
(BTDT)
Old 02-08-2007, 11:24 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
I agree with nate...don't take the wheel off. I have pulled mine numerous times without pulling the wheel. It's really pretty easy and only takes about ten minutes to get the cluster out. If you need specific instructions let me know. The hardest part is finding all the screws in the cover...some are well hidden in the ac vent.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 02-08-2007, 12:18 PM
tnporsche's Avatar
Ok, thats good to hear!
( I have stock wheel for 88 na )
I 'll give it another go. I have the vent ones out.
Oh BTW Do u guys know of any upcoming pelican get togethers?
Lowell
Old 02-08-2007, 05:30 PM
I don't know of any soon. If I hear of one, I'll let you know.
Tom
Old 02-08-2007, 06:02 PM
tnporsche's Avatar
Thanks, Too cold right now, too much salt!!!!.
Around here they really go overboard. 1 " snow and they out down 2" salt. Well maybe not that much, but we had a little snow here five days ago and there is still salt dust at every intersection. LOL
Lowell
Old 02-08-2007, 06:39 PM
tnporsche's Avatar
Yes I got it out no problem. While I have it out I was going to look for what might be causing the oil and temp gauges to peg. Thump on the cluster and it causes them to be right.
In the photo below at the 2 places marked is what looks like corrosion or crud of some type.
Could that be causing the fluctuating gauges? And should I attempt to clean those areas? And if so with what?
In the photo below at the marks. Is something missing? Its on the side near the oil pressure. Maybe lights not needed because its a auto maybe?
Lowell
Old 02-14-2007, 09:34 AM
Lowell,
Check out this article in the tech section.
http://www.pelicanparts.com/techarticles/944_taillight/944_gauge_problems.htm
Tom
Old 02-15-2007, 06:55 AM
Send a message via AIM to hpaulb
The easiest way to clean them is with an pencil eraser. If a little more abrasion is required, use an ink eraser.
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 02-15-2007, 08:47 AM
