Old 928 Guy
surfdog4's Avatar
Fixing the Shifter
well my shifter was wobbly, i didnt realize just how badly until i drove another 944. Figuring it was the plastic bushing, I took apart the shifter.
turns out the pin on the shifter handle was worn into a cone shape!. the bushing was broken, and the rubber boot was split in several places
So i got the replacement parts, just finished installing them and wow it's like a completely different shifter.
In a nutshell, easy job, $82 in parts..big difference...if your shifter is loose, take a close look before you just order that plastic bushing!
1990 C2 Cabriolet Guards Red
'81 928 Zinnmetallic Project Car (sold) )
'87 944na Maraschino Red Metallic (sold) )
Old 02-20-2007, 04:30 PM
winter-hater club member
nynor's Avatar
mine is worn out the same way...
a few weeks ago, i went to put the car in gear and it died, i could move the shifter itself in a very large circle. so, i start the car, get it going, barely, because it was in third gear, it dies again, i start it while moving, get it onto the side of the rode and start wondering how i am going to get the rest of the way home.
so, i pull the boot off, etc., and find that the lever has come out of the sleeve thingy, and the part of the lever that goes in there is completely worn. i get it in there, drive to home dump, and get a circlip to put on the end of the little shaft, along with a couple of nylon washers. when i get home, i lube it with motorcycle chain wax and call it a day. i have to replace the boot and everything, so i think i'll just replace the whole lever this spring.
"COOL PRIUS!" - Nobody Ever
Old 02-20-2007, 05:30 PM
80 dollars in parts for a bushing??? wowie we wow
Old 02-20-2007, 05:42 PM
nynor's Avatar
you have to buy the whole lever.
Old 02-20-2007, 05:44 PM
Old 928 Guy
surfdog4's Avatar
Lever: ~$49
rubber sleeve: ~$28
Plastic bushing: $4
Old 02-20-2007, 06:38 PM
nynor's Avatar
^exactly.
Old 02-21-2007, 08:01 AM
Do a search, there is a fix entailing a drill and a bolt that works well.
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 02-21-2007, 09:23 AM
nynor's Avatar
oh yeah, i remember seeing that. that's what i am going to do.
Old 02-21-2007, 09:30 AM
Old 928 Guy
surfdog4's Avatar
I thought about drilling out the pin, but i figured..what the heck this is probably the first and last time I ever have to do this...It's a pretty big pin and seems to be fairly hard metal
Old 02-21-2007, 10:12 AM
Eldorado's Avatar
From FRWilk's old website
Definitions
shift lever - stands up vertical and has the shift knob attached.
shift rod - it lays horizontally between the tranny and the shift lever.
When I bought my 84 944, the shifter was so bad it hit the frame and rarely would go into second gear. It was cutting the leather boot between the frame and lever. I replaced the "shift lever" for about $60. It got much better but still very sloppy.
The shaft on the "shift lever" suffers wear on both ends, hourglassed shape. Also, the mating 1 inch long hole in the "shift rod" suffers damage. Simply replacing the "shift lever" does not make it shift like new again.
Use a reversible hand drill and go up in size each time. Drill sizes, 13/32, 27/64, 7/16. Twist the "shift rod" so it is pointed up at an angle as in second gear. Then run the 3 drills through the hole in the "shift rod".
Use a good epoxy and glue the brass tubing (0.95 in long) over the worn shaft on the "shift lever". When it is setup, grease it up good and put it back on the car. Everything will feel real tight again.
The brass tubing is a hobby store item. K & S Engineering sells to hobby stores exclusively. The wall thickness is 0.015 inch nominal.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 02-21-2007, 11:37 AM
Old 928 Guy
surfdog4's Avatar
my shift rod did not seem to be worn that much...so i left it alone..the brass insert is a neat idea though
Interesting that the pin on my shift lever was worn to a "cone" shape, not an hourglass...maybe the P.O. only used low gears?
Old 02-21-2007, 12:13 PM
Eldorado's Avatar
mine has worn to a cone shape too... looking to repair it soon..
how easy is that pin to get out?
Kyle
Old 02-21-2007, 07:34 PM
pokey's Avatar
Send a message via AIM to pokey
Pretty easy. use a grinder to get rid of the weld, and the pin pretty much falls out.
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 02-21-2007, 08:04 PM
shikzachaser's Avatar
If you have to buy the lever anyway look @ the Speedforce short shift. You also have to buy a MOMO or equ. knob but the difference is amazing.
84 944 (my favorite all time car)
98 M3 (the wife's)
ML55AMG
03 Eurovan
00 Land Rover Disco II
Old 02-23-2007, 11:14 PM
