Parrothead member
VINMAN's Avatar
Failed emissions again??
Just went back to have my reinspection and fail the emmission test . last time it failed because the NOX level was way high.
so i replaced the O2 sensor gave it a tune up , new plugs etc...
Now the NOX level dropped way down below the limit and the CO level spiked to almost tripple what it was before???
Vinny
Old 02-21-2007, 06:01 AM
Parrothead member
VINMAN's Avatar
32 views, no ideas??
Vinny
Old 02-21-2007, 07:59 PM
SoCal Driver's Avatar
Move to a different state.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-21-2007, 11:35 PM
If your Cat is older than say 6 years, would try changing that. High flows also give you a bump in power. http://www.lindseyracing.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=LR&Product_Code=LR-951-EXH-3ACC&Category_Code=
Would need a shop to weld em in thoe.
Also maybe some gas additive for pre smog test. Something .. Blue?? Heard it mentioned on this site before.
Tip: Run you Car for 25 mins + prior to test. Don't Shut it down in parking lot. Keep it hot and will help.
Good luck.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 02-22-2007, 04:09 AM
That Guy
Techno Duck's Avatar
High CO typically means you are running rich. How old is the fuel pressure regulator. How about the DME temp sensor?
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 02-22-2007, 04:15 AM
Parrothead member
VINMAN's Avatar
A smart a$$ answer from Hugh, imagine that!
Thanks for the tips guys. Its frustrating, it passed with no problem a few months ago. I had to get it reinspected the first time after I replaced the windshield last month. It really dont seem to be running rich. When the tech ran the emmisions test he had the thing sitting there idling for about 20 min before he even touched the car. dont know if that had anything to do with it.
Vinny
Old 02-22-2007, 05:13 AM
EMBPilot's Avatar
Send a message via AIM to EMBPilot Send a message via Yahoo to EMBPilot
Vinny,
you have the equipment of doing this yourself, BUT the Meineke on on brick blvd. welded a cat into the test pipe that was on my car. I took the test 15 min later w/ the new cat and had no problems. the car at that time also had multiple vac leaks. They certainly took their time bringing it through as well.
i heard if you run your tank low and add some sort of additive they sell at auto parts stores it will increase your chances too.
please call if theres anything you need that i can lend a hand with. good luck!!
I forgot to add it was 190 bones for the job... the cat they used matched my cat delete pipe so it was a bit larger than the stock one.
1995 993 C2
Old 02-22-2007, 05:33 AM
Parrothead member
VINMAN's Avatar
Thanks Kev! I might try that additive stuff just to get through it. but still want to find the problem. Have a feeling the cat be be the problem.
Hey I cant complain. 178,000 miles with not one problem other than normal maint... dont get that too often.
Vinny
Old 02-22-2007, 07:07 AM
Coming up on your left...
Aufgeladen944's Avatar
Send a message via AIM to Aufgeladen944
Get it inspected upstate. Hell, I'll say it's mine if you want...
1986 Porsche 944 Turbo "S" clone
1998 Honda Accord
Siena College '08
Manager, Mavis Discount Tire
Old 02-22-2007, 07:23 AM
When you live in a state that has enacted draconian emission laws you will get direct answers to "your" problem. Ask them why you are required to have emissions that are lower than the car produces dead stock and brand new off of the show room floor. If you can't confront your state idiots then MOVE!
Old 02-22-2007, 07:32 AM
p-talk's Avatar
Sounds like cat may be a good bet. When mine didn't pass last December, I gave it the full tune-up and changed the O2 sensor and DME temp sensor, and fixed like six vacuum leaks (car was new to me then). I also ran a bottle of Techron through the car. Then it passed, though I still came close on one of the levels (CO I believe), so I'm thinking I may need to replace my cat before next year's test.
Good luck man!
1984 Porsche 944 - Mathilda the needy
2014 Audi Allroad - daily driver
Old 02-22-2007, 07:58 AM
I've said it before, disregard SoCal's advice at your own risk. And honestly Vinman, NJ isn't such a bad state to be from.
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 02-22-2007, 09:04 AM
EMBPilot's Avatar
i love this state, of all the places in the WORLD ive LIVED and seen, id rather live no place else than the shore. you can keep earthquake pollution ridden Cali! you can try and pry this state from my cold over taxed dead hands
1995 993 C2
Old 02-22-2007, 09:25 AM
Parrothead member
VINMAN's Avatar
Cant argue with you on this one Hugh. Our emission laws are a joke. Especially when you see state owned vehicles and buses blowing smoke all over the road. Guess certain vehicles are "exempt"...
Vinny
Old 02-22-2007, 10:13 AM
Parrothead member
VINMAN's Avatar
Our state appreciates your contributions!
Vinny
Old 02-22-2007, 10:14 AM
Graduated User
conkeytonk's Avatar
No emission controls or inspections here, the sea breezes blow all the nasty stuff elsewhere. It’s sunny and warm, we do not have a state income tax and are about to eliminate property taxes. Okay if you don’t buy in though, us Floridians try to keep it a secrete but I would like to see more 944’s zooming around so I’m letting you guys in on it.
Randy
1977 Scirocco Rebuilt 1.7L Stock Grey (Totaled)
1979 Scirocco Built 2.0L Stroaker Blue (Pilfered)
1979 Scirocco Built 1.8L Rust Bucket Tan (See ‘ya)
1982 Scirocco Rebuilt 1.7L Garage Kept Gold Daily Driver
1987 944 NA Rebuilding 2.5L One Female Owner Grey Weekender
Cruising to a conkeytonk in my Scirocco on steroids
Old 02-23-2007, 06:13 AM
Yes but the influx of elderly people is disconcerting. To a young person such as myself, Florida is kind of seen as an elephant graveyard.
Sorry to the old guys on here...
1998 Honda Accord
Siena College '08
Old 02-23-2007, 09:17 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Am I suppose to move to Florida? Probably so. Yeah, they do have some old people there, but when I think of Florida, I think of really nice beaches and spring break....well, you know the rest. Maybe it's a perception thing.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 02-23-2007, 01:20 PM
Graduated User
conkeytonk's Avatar
Paradise Tom, and no emission controls! Come join us conks.
Randy
Old 02-23-2007, 01:34 PM
My next vacation...I'm there. Probably in a couple months....wanted to come next month but I volunteered to help a friend complete a computer project although I'm suppose to be retired....which means I'm definitely suppose to be there.
Tom
Old 02-23-2007, 03:14 PM
