armandodiaz's Avatar
Installing 3-point rear seat belts
I'm looking to upgrade my rear belts from lap to shoulder. I have an 87 944na. I just bought a used set of shoulder belts and I can't figure out how/where the retractable section mounts. I see the bolt hole on the outside part of the seat and the bolt hole near the rear hatch. Where is the other bolt hole. Does anyone have pictures they can post?
Armando Diaz
85 911 Carrera - Track car
01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996
87 944na - Old Daily Driver, now 944 CUP
03 Chevy Avalanche- Support Vehicle
70 Olds 442 W30 Conv- Gone but not forgotten
http://www.diazracing.com
adiaz@diazracing.com
Old 03-17-2005, 07:23 PM
Verruckt's Avatar
I too just bought rear three point belts. There are two anchor locations where the stock lap belt are and the third is on the C pillar. I will post when I am done. Good luck,
The crashes people remember, but drivers remember the near misses. – Mario Andretti
1991 944S2 Rally #951 Rally-America.com
Old 03-19-2005, 08:08 PM
SoCal Driver's Avatar
What rear seats?????
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-20-2005, 10:32 AM
I see the two by the seats, one is for the lock. The second one and the C pillar is for the retractable section. But there should be a fourth one where the mechanism itself bolts down to.
Armando Diaz
Old 03-21-2005, 12:41 PM
Sent you a pm Verruckt
Armando Diaz
Old 03-21-2005, 05:10 PM
Bump of a old thread. I am also looking to install the three point rear belts in my 88NA. Can I see a picture or two of someones car that has them.
I called 944 ecology and was told my year 944 did not have the option for three point belts, yet I have searched and read threads here with other 88 944 owners that have them, so.....
do they or don't they and how do I tell if mine does or doesn't?
Garold Shaffer
1973 914 2.7 /4 Flared Beast - SOLD
74 2.0 Daily Driver
74 LE Bumble Bee Project car
Old 03-28-2007, 09:16 PM
Custom User Title
Dave L's Avatar
my 88 has them, here are the pics
Old 03-29-2007, 05:53 PM
I think all S and Turbos came with them
Armando Diaz
Old 03-29-2007, 05:57 PM
Verruckt's Avatar
Wow, I haven't thought of this post in a long time. My car didn't have the pre-drilled hole or the panel for it behind the carpet. I had to "go my own way" to install my 3pt belts. Pull back your carpet and you will see a metal panel with a pre-drilled/tapped hole for the large bolt that holds the seat belt retractor. Make a hole in the carpet in the proper spot and the rest is easy. If you don't, you are in for a lot of extra work. I installed mine for the purpose of holding my kids booster seats. Being a concerned parent I also used a 10K lb tie down strap through the back of the boosters so they won't move even if my weld did. Your results may vary. Good luck.
Old 03-29-2007, 06:11 PM
Thanks for the pictures. I'm new to 944 (I'm a 914 guy) I hate to ask, but could I get one more picture just showing the complete back seat and belt? I think I know where you are talking about, but just want to make sure.
Thank you!
Garold Shaffer
74 2.0 Daily Driver
Old 03-29-2007, 07:13 PM
