It"s Alive!
This is the 87 that I towed home from NY. It's been sitting in my garage as I gradually made its aquaintance. I disassembled the front end of the motor to check on the situation as far as belts goes, and having found that they didn't look too bad I decided to check my compression. Couldn't get the thing to turn over although it was getting juice to the starter. Took the starter off and disassembled it and the cable that runs from the solenoid into the brush unit was completely rotted off. Nobody seems to sell parts for these although you can get rebuilt starters so somebody must make brushes...
Any how found one used on ebay for about $40 and after a week or so it arrived. Results range from 180 to 190 psi. For what its worth, when I started cranking the first cylinder only pumped up to about 145 and the second one was higher and the third one full pressure. I figure that the bores and rings and pistons were pretty dry. After the fourth one I went back and tried the first and second - sure enough - 190. So anyway I thought I'd try to fire it up - not remembering that I had unplugged the AFM as well as the sensor connections at the back of the head. Obviously no start. Any way later I remembered what was disconnected and tonight after making the right connections it fired right up. Only for a moment of course - I need to do the belt and probably rollers, etc. But hey It sounded pretty good.
Andy D. Currently driving 2005 Audi A4 Currently driving 2006 Ram 1500 sometimes |
So because the existing belts "didn't look so bad" you left them on the engine?
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
winter-hater club member
i think he means to change the belts asap. he just wanted to hear it fire up
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
yeah, it's nice to get reassurance that you're not wasting your time... I've been known to fire engines (briefly) without any belts at all just to make sure they'd run before spending my time/money on stuff like new water pumps etc. - of course this doesn't work on a Porsche! if you don't have a belt, you're walking!
nate
1988 944... and a bunch of other cars
marvel mystery oil is the ticket for dry starting any motor
or reviveing a motor that has sat its still not ot late a little squirt in each hole will free up all rings good luck
1986 944 n/a hard top, black on burgundy |
Definately belts etc. is next on the list - just hate to spend money and effort if the rest of the motor was junk.
