-   -   O2 Sensor (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/336792-o2-sensor.html)
dan476 03-20-2007 05:22 PM
O2 Sensor
I need to replace my O2 Sensor. I have an early 944 so its a single wire sensor. Is there a universal type i can use or any after market types? as PP wants 130 for a new one.
ae1969 03-20-2007 05:56 PM
YUp.... there is a post on here regarding the part number.
dan476 03-20-2007 06:17 PM
any idea where the post is? i tried Search, but couldn't find it.
Techno Duck 03-20-2007 06:29 PM
Bosch 11027 or 0 258 001 027 (same thing).
List price is $25
dan476 03-20-2007 07:23 PM
Awesome, thanks.
One more thing, The brown connector for O2 Sensor wire, above speed and ref sensor. Well that connector has snapped off on me, the brown part, just fell apart from age. does anyone know the part # for that connector?
http://i115.photobucket.com/albums/n.../Porsche08.jpg
SoCal Driver 03-20-2007 07:32 PM
The O2 sensor.
dan476 03-20-2007 07:42 PM
SoCal, are you saying that brown thing is part of O2 Sensor?
I am not quite getting what you said.
speedracing944 03-20-2007 08:24 PM
I bought mine from autozone for about $20 and they had it in stock. just make sure NOT to solder it together but use the crimp connector.
Speedy:)
speedracing944 03-20-2007 08:28 PM
If that brown connector is attached to the end with the O2 sensor and it is broken, you may be better off not buying the universal O2 but the one from Pelican instead. (If it comes with the brown thingy)
Speedy:)
SoCal Driver 03-20-2007 08:33 PM
It is the main connector for the O2 sensor. You should find a black two wire connector close to it. Offset pins. This is the power for the heated sensors.
dan476 03-20-2007 08:54 PM
Hmm does anyone have a replacement for this brown connector?
dan476 03-20-2007 08:56 PM
SoCal, what connector are you talking about? also do you have a part # for it?
SoCal Driver 03-20-2007 09:12 PM
Butt splice the new sensor to the wire on the other side of the connector.
