O2 Sensor
I need to replace my O2 Sensor. I have an early 944 so its a single wire sensor. Is there a universal type i can use or any after market types? as PP wants 130 for a new one.
Dan '84 944 - Under construction '77 924 - Sold '05 Jeep Liberty '98 Acura Integra |
YUp.... there is a post on here regarding the part number.
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
any idea where the post is? i tried Search, but couldn't find it.
That Guy
Bosch 11027 or 0 258 001 027 (same thing).
List price is $25
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Awesome, thanks.
One more thing, The brown connector for O2 Sensor wire, above speed and ref sensor. Well that connector has snapped off on me, the brown part, just fell apart from age. does anyone know the part # for that connector?
Dan '84 944 - Under construction '77 924 - Sold '05 Jeep Liberty '98 Acura Integra Last edited by dan476; 03-20-2007 at 07:41 PM.. |
The O2 sensor.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
SoCal, are you saying that brown thing is part of O2 Sensor?
I am not quite getting what you said.
meister member
I bought mine from autozone for about $20 and they had it in stock. just make sure NOT to solder it together but use the crimp connector.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
meister member
If that brown connector is attached to the end with the O2 sensor and it is broken, you may be better off not buying the universal O2 but the one from Pelican instead. (If it comes with the brown thingy)
Speedy
It is the main connector for the O2 sensor. You should find a black two wire connector close to it. Offset pins. This is the power for the heated sensors.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! Last edited by SoCal Driver; 03-20-2007 at 08:42 PM.. |
Hmm does anyone have a replacement for this brown connector?
SoCal, what connector are you talking about? also do you have a part # for it?
Butt splice the new sensor to the wire on the other side of the connector.
