tnporsche's Avatar
hot hot relay
At random times the ac interior blower fan will stop.
The relay G1 gets real hot. If I tap on that relay, It starts again. (short silver metal relay at the front)
Is this the right relay?
Is it repairable?
And just how hot should that get?
Lowell
1988 944 Red Project car (Now daily driver, Daughter's to school ride)
1983 944 Grey NEW Project car
http://www.pelicanparts.com/gallery/tnporsche
Old 03-22-2007, 05:33 PM
winter-hater club member
nynor's Avatar
something may be drawing too much current, due to a bad ground, or something.
"COOL PRIUS!" - Nobody Ever
Old 03-22-2007, 05:59 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
They shouldn't get hot...at best just slightly warm. I'm with nynor...probably the motor. Take it out and clean the bearings in the end and put sewing machine oil on the bearings where the shafts come out ....or if affordable replace it.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 03-22-2007, 08:40 PM
If tapping fixes them then you should replace the relay. Commonly the cheap single sided circuit board solder joints fail. you Can also Re-solder them and probably fix the problem. When it slides around it arc's and causes much heat and bad connections. Look for gaps between the feedthru pins and the Solder pads for the Bads.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 03-22-2007, 09:17 PM
Send a message via AIM to hpaulb
Find the high current draw source and repair. Replace the relay as it is not the cause but would be damaged because of it. I usually have good luck with the oiling of bearings as stated above. When you spin the fan, you should be able to assess the wear by the sound.
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 03-23-2007, 07:24 AM
I would replace the fan motor.
Old 03-23-2007, 04:41 PM
ERAU944's Avatar
Send a message via AIM to ERAU944
hot hot relay... geez i was expecting to see gorgeous chicks in bikini's handing off a baton!
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 03-23-2007, 05:18 PM
I've got a bunch of relays I pulled out, if you want a used replacement let me know what the part # is and I'll see if I have it. Cover the shipping and it's yours.
-- Jim
1983 944
Old 03-23-2007, 05:23 PM
tnporsche's Avatar
Ok, I'll pull motor and clean. Just in case, I ordered another motor.
Just FYI I took the cover off the fuse box and it no longer cuts out. But I know I cant run it like that. Just interesting....
Thanks #39 I'll check
LOL...... bikini relay... a cool visual. If only I lived in CA.
Lowell
Old 03-24-2007, 07:10 PM
