Send a message via AIM to bholmes
CV axle same as VW?
I was looking for the cheapest replacement CV axle shaft assembly and while searching the net I came accross these two links
http://roctronics.com/axles/axle1987VOLKSWAGENVANAGON.htm
and
http://www.autopart.com/axles/axle1985PORSCHE944.htm
Note the common 60-7077 part number. Are these the same shafts? Kind of looks like it to me. I was just curiouse if there are cheaper prices and higher availability for the VW shaft if it's the same.
Brian
'86 944 NA
'94 Jeep Cherokee 3" and 31's
'86 Chevy C10 425hp
'98 Dodge Neon (the wife)
Old 04-04-2007, 05:56 PM
Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
I believe I was told in the past that the shafts were the same as a "Thing" so it is entirely possible. The bolts are the same as VW I can tell you that much.
I've also been told to get the genuine Lobro/GKN CV joints whenever possible, as some of the aftermarket ones are not so good. I've actually got one axle for an '88 NA 5-speed laying around with very few miles that was replaced while searching for the cause of a mystery vibration. Do ya feel lucky?
nate
1988 944... and a bunch of other cars
Old 04-04-2007, 05:59 PM
Thanks for the offer nate, but and need two and I don't believe I'm that brave, it's my DD so buying a new set will pay off in the end. I just ordered a set. Seems the VW axles are no more prevelant than the Porsche ones.
Brian
'86 944 NA
'86 Chevy C10 425hp
Old 04-04-2007, 08:53 PM
Usually only the left one goes bad, why waist your money if the right one( or visa versa) is still OK. Trust me the money will come in handy for something else.
Mark
'86 944NA
'10 VW Golf 2.5 5sp
'99 BMW 540i Sport Wagon
Old 04-05-2007, 10:36 AM
From my inspection they both seem to be in need of repair. The one on the right/passenger side is the one that is actually making all the racket. I know typically it's the other one that goes bad, but my car was in a fairly poor state of disrepair and neglect when I bought it a month or two ago. So I figure two new shafts and 4 new joints will give me a place to start, then I know what needs serviced when. Thanks for the input though.
Brian
'86 944 NA
'86 Chevy C10 425hp
Old 04-05-2007, 10:55 AM
SoCal Driver's Avatar
If one axle is bad so is the other. You can buy the CV's separate or on an axle. Be sure to use new bolts.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 04-05-2007, 04:14 PM
Ok, thanks for the advice SoCal. I had neglected to order new bolts, but I'll get on that.
Brian
'86 944 NA
'86 Chevy C10 425hp
Old 04-05-2007, 07:49 PM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
both while you are there.
Has anyone compiled a countermatch list?
It would be great to know what fits what for these cars.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 04-05-2007, 08:07 PM
