-   -   I need to open my darn window (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/338806-i-need-open-my-darn-window.html)
magilla gorilla 03-31-2007 03:39 PM
Is there anyway to touch the pin contacts with a wire to open and close my power window motor..I cleaned my toggle switch contacts to no avail..Before I messed with it, the window was working (slow) but at least it opened..
ERAU944 04-01-2007 07:51 AM
did you put the switches back together correctly? if you reverse one or both of the contacts, the switch will not work properly
magilla gorilla 04-01-2007 04:43 PM
the 5 pins on the toggle swith will only go in the harness one way..I,m now thinking that the power motor is shot, but I still would like to short the switch so I can see if the motor will work at all
SoCal Driver 04-01-2007 04:56 PM
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/327552-confused-about-windows-again.html
magilla gorilla 04-02-2007 04:47 PM
thanks So Cal I,ll try jumping the pins and see what happens..
ERAU944 04-02-2007 07:33 PM
i meant actually taking the switch apart, as in exposing the innards, not just taking the switch out of the retainer.
Aerkuld 04-02-2007 08:27 PM
Right - you can put the internals back together the wrong way around. The PO of my 944 had done this on the passenger side switch.
