magilla gorilla's Avatar
Send a message via AIM to magilla gorilla
Cool I need to open my darn window
Is there anyway to touch the pin contacts with a wire to open and close my power window motor..I cleaned my toggle switch contacts to no avail..Before I messed with it, the window was working (slow) but at least it opened..
Old 03-31-2007, 03:39 PM
ERAU944's Avatar
Send a message via AIM to ERAU944
did you put the switches back together correctly? if you reverse one or both of the contacts, the switch will not work properly
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 04-01-2007, 07:51 AM
the 5 pins on the toggle swith will only go in the harness one way..I,m now thinking that the power motor is shot, but I still would like to short the switch so I can see if the motor will work at all
Old 04-01-2007, 04:43 PM
SoCal Driver's Avatar
confused about windows, again
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 04-01-2007, 04:56 PM
Cool
thanks So Cal I,ll try jumping the pins and see what happens..
Old 04-02-2007, 04:47 PM
ERAU944's Avatar
i meant actually taking the switch apart, as in exposing the innards, not just taking the switch out of the retainer.
Old 04-02-2007, 07:33 PM
Un Chien Andalusia
Aerkuld's Avatar
Right - you can put the internals back together the wrong way around. The PO of my 944 had done this on the passenger side switch.
2002 996 Carrera - Seal Grey (Daily Driver / Track Car)
1964 Morris Mini - Former Finnish Rally Car
1987 911 Carrera Coupe - Carmine Red - SOLD :-(
1998 986 Boxster - Black - SOLD
1984 944 - Red - SOLD
Old 04-02-2007, 08:27 PM
