Installed XM Radio This Weekend
I put in a new stereo a couple of months ago that was XM ready, and this weekend, I got the XM kit needed to use it.
When I read all of the directions, it stated that the antenna must be mounted outside of the car - preferably on the roof with a minimum of 12 square inches of metal around the antenna. It said to definitely not mount the antenna on the dash.
Well, I was a little disappointed as I definitely don't want this antenna on the roof and I don't want any exposed wires being tucked into the window molding. My friend has his antenna on his pickup's dash and it works fine. Unfortunately, the 944 dash is a little smaller.
So, I came up with my own idea and it works perfectly and definitely looks custom - see below:
The antenna installed using the rear wiper mounts:
I cut a piece of metal and shaped it with a grinder for the mount and then painted it black:
Ran the antenna wire thru the stock wiper tube and then to the front of the car:
170 channels of commercial free music for $9.95 a month - the XM receiver fit behind the passenger foot rest - next to the DME
Old 04-04-2007, 09:55 AM
Hoss Ghoul's Avatar
Send a message via AIM to Hoss Ghoul
Nice solution. I ran my antennae under the door/floor moldings and mouned it on top of the hatch strut, works perfectly and no one can grab it, etc.
1987 924S
2000 Camaro Z/28
Old 04-04-2007, 05:46 PM
I was lucky because the antenna wire was exactly the correct length. I had about 4" to spare. I mounted the xm receiver under the passenger foot-well right next to the DME and everything is getting great reception.
Old 04-05-2007, 11:09 AM
