Custom S2 Intake, Check it
See I work at a car dealership, and a Nissan 350Z came in with this cold air intake on it. I got the intake for free, then chopped it with a hacksaw to make about a 45 degree bend for the S2.
-Whatya think? http://forums.pelicanparts.com/uploa...1178930363.jpg |
Finally! The correct way to install an aftermarket cold air intake. Nice job. Now are you going to get the Turbo batwing to go with it?
Is there an incorrect way?
I saw this once upon a time. It's cool/correct because unlike a cone mounted in the engine its not exposed to the hot underhood air. With a vented header panel you can get the coolest air possible. This is the only kind of cone I would mount.
Way to make use of that empty space where the intercooler would go. Actually, that's probably a pretty effective setup.
You will have to clean and/or replace the cone filter far more often than a stock setup. Also the cone does not filter out the road dust as good as the stock filter.
The slots by the license plate actually vent up to the filter, at least the top one is a direct flow to the cone. http://forums.pelicanparts.com/uploa...1179002896.jpg
ahh forgot it was an S2, the vented nose panel would look cool though!
Re: Custom S2 Intake, Check it
the pipe is 3" diameter I'm almost positive(the same as original S2), I have no idea who made the Z intake. At autozone/orielly in the ghetto customization isle, they sell like different pipe sections. A small straight section and a 45 degree bend with a silicone hose clamp should get the job done.
-Where chrome piped ends opposite the filter, it goes into a rubber hose clamp, then to the MAF box. It's like a 45 degree silicone/rubber clamp. It's factory, so yours should have it. -As for filter support, there is a bracket I zip-tied to around the filter. The bracket then goes onto a little like 10mm nut just like the one pictured, except on the other sidehttp://forums.pelicanparts.com/uploa...1179348768.jpg |
