Custom S2 Intake, Check it
See I work at a car dealership, and a Nissan 350Z came in with this cold air intake on it. I got the intake for free, then chopped it with a hacksaw to make about a 45 degree bend for the S2.
-Whatya think?
Old 05-11-2007, 05:46 PM
Politically Incorrect
onZedge's Avatar
Finally! The correct way to install an aftermarket cold air intake. Nice job. Now are you going to get the Turbo batwing to go with it?
Edek
'87 924S
'91 535i
Old 05-11-2007, 05:53 PM
Is there an incorrect way?
-1989 S2
-1986 Land Cruiser
Old 05-11-2007, 06:26 PM
Will work for parts
944 boy's Avatar
Send a message via AIM to 944 boy
I saw this once upon a time. It's cool/correct because unlike a cone mounted in the engine its not exposed to the hot underhood air. With a vented header panel you can get the coolest air possible. This is the only kind of cone I would mount.
'88 944 240,100 miles -race car
'05 Boxster 110,000 - Daily Driver
'74 911 Targa - long term project
Old 05-11-2007, 07:01 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Way to make use of that empty space where the intercooler would go. Actually, that's probably a pretty effective setup.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 05-12-2007, 08:54 AM
Custom User Title
Dave L's Avatar
with a cone filter like that in the engine bay all its going to do is suck in hot air which will hurt performance. Routed up to the front and with a vented nose panel from a 924turbo the filter will get lots of nice cold air which makes everyone happy
Old 05-12-2007, 10:11 AM
SoCal Driver's Avatar
You will have to clean and/or replace the cone filter far more often than a stock setup. Also the cone does not filter out the road dust as good as the stock filter.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 05-12-2007, 11:12 AM
The slots by the license plate actually vent up to the filter, at least the top one is a direct flow to the cone.
Old 05-12-2007, 01:49 PM
Custom User Title
Dave L's Avatar
ahh forgot it was an S2, the vented nose panel would look cool though!
Old 05-12-2007, 05:14 PM
Re: Custom S2 Intake, Check it
-Whatya think?
I heard I could do this--looks like it can breath twice stock. What is the paper (ok-fiber) filter cone--a K&N? I assume that's the borrowed part? And who makes the plumbing--is that the Z part you stole andcut--is it stock S2 diameter? If that goes through from the front plenum to the motor compartment at a different than stock diameter, please show a pic of how/where. Does the cone canister sit free on the end of the pipe, or does it have a support at the far end? What do you think you get for hp increase at higher revs, where breathing is important? I want details so I can do it when I put in a chip.
Boxers: '72 914 1.7 w/ AA's 9014 body kit, '73 914 2.0, '87 Westfalia VW, and '90 Subaru 2-whl. dr. wagon (beater); AND the "new" '90 944 S2 Cabrio--not a boxer
Q: Why do some guys like BMWs?
A: Because they can spell it.
-- AIM HIGH - You just might hit the moon! And if not, people will think you're a real spaceman, anyway.
Old 05-15-2007, 11:29 AM
the pipe is 3" diameter I'm almost positive(the same as original S2), I have no idea who made the Z intake. At autozone/orielly in the ghetto customization isle, they sell like different pipe sections. A small straight section and a 45 degree bend with a silicone hose clamp should get the job done.
-Where chrome piped ends opposite the filter, it goes into a rubber hose clamp, then to the MAF box. It's like a 45 degree silicone/rubber clamp. It's factory, so yours should have it.
-As for filter support, there is a bracket I zip-tied to around the filter. The bracket then goes onto a little like 10mm nut just like the one pictured, except on the other side
Old 05-16-2007, 01:53 PM
