DME Failure
Hi All,
Just determined that my DME is failing. I noticed in the BMW Tech Articles, there is a rebuild for the Bosche DME. (http://www.pelicanparts.com/BMW/techarticles/E36-DME-Repair/E36-DME-Repair.htm
Pelican Technical Article: BMW DME Motronic ECU Swap / Repair) Has anyone used it to try to fix a DME?
Old 06-01-2007, 02:02 PM
winter-hater club member
nynor's Avatar
yeah, do a search. people have had success resoldering the connections, etc. if that fails, get one off of evilBay. what car do you have?
"COOL PRIUS!" - Nobody Ever
Old 06-01-2007, 02:12 PM
Hi Nynor,
I have a 1988 944. Plain jane, no S, no turbo. Interesting though, its more like an 87 - supposed to have ABS - it doesn't, supposed to have airbags - doesen't.
Old 06-01-2007, 06:39 PM
nynor's Avatar
i think they were options. mine doesn't have ABS, but does have airbags (which i promptly disabled).
Old 06-02-2007, 05:37 AM
Engine swap pro
myskyon's Avatar
Originally posted by knights89
Hi Nynor,
i believe the air bags became standard on the 951 in 87 but remaind and option or the non turbo cars untill 88-89 also if your car has the option for the 30mm steering hub that will delete the air bag wether its standarad or not. but that would only be the drivers side. as for abs the only car to have it standard is the 952 (turbo s). check your option codes on the rear part of the hatch wall under the carpet and look them up.
87 951 ---- "R2" - under the knife
87 951 ---- "R1" Parting out - Gave to a good friend
88 951 ---- Black one - recieved as a trade for my 87 - very mint - parting out
06 WRX ---- The "RUE"
Old 06-03-2007, 06:57 PM
ERAU944's Avatar
Send a message via AIM to ERAU944
turbo S is not 952 ( i think that's a RHD 951), but yes the only 944/951 series to have ABS standard is the 951S
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 06-03-2007, 07:06 PM
I believe all Late DME - 1985.5 to 1989 Porsche 944 use the BOSCH Model ML3.1 Motronic software but according to FRFILK.COM different model years use specific DMEs so I don't know how well swapping with a BMW will work out.
Your '88 uses DME 0 261 200 086
For comparison:
'86 uses DME 0 261 200 076
'89 uses DME 0 261 200 089 for the 2.7 litre engine
The only thing you could do is try swapping different DMEs to see if they work but before you do that you may want to try resoldering the connections on the DME out of your own car to see if that will solve your problem. Here is a web tutorial that will get you started.
http://www.rennspeedracing.com/DME_tutorial.html
Mark
'86 944NA
'10 VW Golf 2.5 5sp
'99 BMW 540i Sport Wagon
Old 06-05-2007, 07:56 AM
