Tire pressure on 1984 Porsche 944
Yeah cant find the sticker I think my mechanic might have removed itand the tire pressure is at 37 PSI on my Yokohama AVS ES100s ... And I searched all over google, lol.
Thanks in advance. |
The manual says that for a 944 n/a up to MY 89 the front is supposed to be "2.0 bar excess pressure" and the rear is supposed to be "2.5 bar excess pressure." I am not sure what the conversion is though. I'll look it up and see if I can find something.
John '87 944 N/A (first Porsche) '95 E-350 Diesel '03 S-Type Jag 3.0 '03 Taurus SES '06 Eddie Bauer Explorer RIP SoCal |
Found it... http://www.britishmetrics.com/html/pis-bar.htm
2.0 BAR = 29 PSI - Front 2.5 BAR = 36 PSI - Rear So the manual says....
Kewl so would the 1984 model have the same tire pressure requirements ?
That's what the manual says... up to MY (Model Year) '89. Do you have an "n/a" or an "S"? There's also a link on here somewhere with the manuals on it. Grab them while they're still up!
My tire pressure sticker is on the inside of the gas cap and says 29 psi front & 36psi rear. my car is an '88 but I suspect it's the same for your '84.
Misunderstood User
A BAR is equal to 1 atmosphere.
1 atmosphere is 14.7 psi 2 Bar is equal to 2 X 14.7psi 2.5 Bar is 2.5 x 14.7psi 3 Bar = 3 X 14.7psi See how simple the metric system is
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway |
Thank you soo much, I've had the car since november (I've done about 3000km on it twice to TO and back from montreal so havent had time to drive it much) and the tires were WAYYY over inflated 39/39 psi. Got it all fixed now. Still havent drove the car as I've been having a hell of a time geting the spark plugs changed finaly got the right size thing for my ratchet. They aren't bad just that there is a little bit of carbon deposits. One of the wires and the contact was badly oxydised so I'm going at it with iron wool the plug was wet so thats probably why the engine was running abit rough, no so much but it is noticeable to the ear.
