Please read and help if you can,....engine problems
Ok, on moday night i was driving my 944, i only got about 3 miles and the engine just died, my rpm's went flat but i had power to everything else. the engine just turned off.
After trying everything for about 30 minutes i had to be towed home. I went outside tuesday and looked a few things over and didnt see anything wrong but the car still wouldnt start. So today i pulled out a few tools and took one spark plug out and turned the car over to see if there was spark, i didnt see a spark but the car started and ran. I put the plug back in and drove 2 or 3 miles and it runs fine. Can anyone tell me maybe whats going on, im buying new spark plugs today and maybe a coil wire, but im 16 so money is limited till i get a job. any help on this greatly appreciated, thanks josh
1987 944 n/a |
It definately sounds like an ignition problem and by you removing a plug, you must have wiggled some wires around. Run the engine at night and see if you can see any sparking coming out of the plug wires. When they get worn out, you can sometimes see the current pulsing thru (when it's dark out). You may also want to check the conditi0on of the cap and rotor. Also, look for any loose wiring to any sensors as you must have moved something causing the car to startup.
Vern |
Greasy Member
Did you happen to check your DME relay when the car died? Alot of 944 drivers carry a spare, as after time the solder joints can wear out and leave you standed with the same kind of problems you are describing. Note: the DME relay is also often called the fuel pump relay.
Good luck, Nick
Owner: Bennington Motorsports www.benms.com Sponsor for Midwest Region 944-SPEC racing series -When was your timing belt changed or tensioned?? -Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP. |
Feelin' Solexy
Re: Please read and help if you can,....engine problems
Grant In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S |
Feelin' Solexy
Dang, Tidybuoy beat me to it! Also Many944s has a good suggestion...
Certified Rennwerker
I carry a new relay as a spare just for the above reason. They seem to fail at the worst time too.
![]() Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Cam reference sensor? DME would be 2nd guess.
is there a way to check the dme relay? yes the engine was cranking but would not start, i will drive the car tonight and check the spark,
1987 944 n/a |
also i have another question, this time its aobut my oil pressure, when driving the car around my oil pressure stays at 5 all the time somtime just a little lower somtmes a little higher, is this normal or not. thanks josh
1987 944 n/a |
I think that is normal. My car runs at 5 but occasionally will dip to 3 when idling.
Vern |
Feelin' Solexy
Or if you've got a no-start condition and suspect the DME, you can jumper the connections (don't drive the car around like this...diagnostic only). Check out Clarksgarage.com for a good explanation of how to jumper.
ive been driving the car all around and it hasnt died, would you say it is safe to drive until i get a new dme? thanks josh
1987 944 n/a |
Feelin' Solexy
im purchasing a new relay, ill attempt to drive it around, i it dies again then ill know its the relay, and ill just park it till the new one comes or ill try to fix this one, im pretty good at soldering. thanks for everyones help, josh
1987 944 n/a |
