Brake Pad Reccomendations
I just bought a set (4) of slotted brake rotors for my 1988 n/a. I bought these from 944online.com and they also sold me Metal Master Brake Pads.
I had previously bought a set of Pagid brake pads (I think they are Pagid but they might be Jurid - I'll have to check). The guys at 914online.com told me that they recommend Metal Master because they are softer than the Pagid and the Pagid's are harder on the rotors.
I was just wondering what you guys think. My car is used for street use only. I realize that I don't need slotted rotors but they look good. Unfortunately, they;re not turbo rotors as I don't have the spindle upgrades at this time.....but down the road, I'd like to switch over to the larger setup that's on the turbo.
Thanks.............................Vern
Old 06-28-2007, 11:47 AM
cold starter
JustinL's Avatar
I really like metal masters for my n/a. More pad than I ever needed for street and autocross. I liked them enough to try them on the 951... On track, the 951 made them catch fire so I had to change to kfp magnum golds.
88 Turbo S Silver rose: Megasquirted fuel, assorted suspension upgrades, etc.
89 944 S2 with 968 engine: Race car
87 944: Chump car build in progress
Old 06-28-2007, 12:23 PM
Thanks for the info. I will have to wait a week before my rotors and pads get here but I can't wait.
Old 06-28-2007, 05:33 PM
Aslet's Avatar
For the metal masters, are there different brands of "metal masters"? I ordered the metal masters off 944 online, and when i got them i see they are made from PBR... I had always looked at Axxis ones. Anyone know the differance, they both are XBG Semi-met pads.... Should i return these and get the Axxis ones (i was recommended these)?
Old 06-28-2007, 06:25 PM
74goldtarga's Avatar
They are exactly the same. If you order from Paragon products you might get PBR/Axxis/Metal Master. Manufacture is identical, don't sweat it. I have these on my car, cheap, quiet, dusty- did I mention cheap. They work well on the street. Wouldn't bother with Pagid for the street - depending on compound will be expensive and loud, and may eat your rotors. I have Porterfield R4 for the track, great pad, but too loud for the street.
'74 911 Targa - Sold to the highest bidder
'87 944 Turbo - Fix for track addiction
'72 DeTomaso Pantera - Sold to the only real bidder
Old 06-28-2007, 06:36 PM
Aslet's Avatar
Ok, so your sure they are the same? Hehe, I just want to make sure I have the good ones Also, are the very dusty? I dont mind a bit, as I wash my car every 2 weeks at most, I just dont want to get my car covered in brake dust...
Old 06-28-2007, 06:51 PM
They are kind of dusty, but I have a loop by my house where there are some uninhabited roads and I push the car with near threshold braking at times, it might be different with typical use. You can't really get everything out of one pad, I think a little dust is an ok compromise considering the performance at this price point.
Old 06-28-2007, 06:55 PM
Misunderstood User
I am using a set of OE brake pads from Porsche. I found them on EBAY for $70. Haven't had the car on the road as yet to give you a report.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 06-29-2007, 07:27 AM
flash968's Avatar
the metal master were made by repco (that's how old i am), then it became axiss, now they are pbr - same pad - different company name
those pads are fine for average use, and a good budget pad, but they have cold stop issues, and can tear up drilled rotors - i ran them for years on smaller cars and loved hem, but on anything close to 3000 lbs, i have found them to be a little wanting - they also can be known to squeak occasionally
i am currently using the Porterfiled 4S pad, and in 30 years of playing with pads, this is the best thing i have ever found for performance street use (and the occasional track day) - i have yet to have them fade on my 968, and the dust is manageable (much better than stock) - not a single squeak either
i will be putting them on ALL of my cars - you get what you pay for
Old 06-29-2007, 08:20 AM
Flash - I am tempted to use the Porterfield 4S for the street as well given my positive experience with the R4 at the track, one set costs as much as 3 sets of the PBRs however.
Old 06-29-2007, 09:24 PM
