DVC DVC is offline
Replacing ignition switch?
Any tips on replacing a late model ignition switch?
Thanks for any help!
Old 06-28-2007, 04:18 AM
Send a message via AIM to Icey1174
http://www.clarks-garage.com/shop-manual/elect-25.htm
That will help if you don't already have it.
John
'87 944 N/A (first Porsche)
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
'06 Eddie Bauer Explorer
RIP SoCal
Old 06-28-2007, 07:00 AM
Sorry, that looks like an early model.
John
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
RIP SoCal
Old 06-28-2007, 07:02 AM
DVC DVC is offline
Thanks John!
944 LS2 6-liter
Dyno Video
Old 06-28-2007, 12:33 PM
I have read some posts where the people say they took the whole dash out to reach one screw.
John
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
RIP SoCal
Old 06-28-2007, 12:39 PM
legoland951's Avatar
There are 2 screws that are designed to have the "head" break off after install so no sockets can be used to remove them. Its for security reasons but makes it next to impossible to remove without removing the dash and drilling them out. What part of the ignition switch do you have to remove? The mechanical portion where the key goes in or the electrical portion on the other side of the assembly? There are tricks to remove the tumbler assembly by drilling a small hole and depressing the retaining clip inside the lock to remove it.
There is no mechanical task so great that brute force and ignorance cannot overcome
Old 06-28-2007, 01:11 PM
I replaced the electrical switch at the back of the ignition barrel on my s2cab last month.
First off i tried to access it from underneath the dash drivers side footwell but it was damn near impossible for me so i ended up removing the steering wheel, plastic dash surround and the speedo clocks etc to access it.
There's two small screws that secure it from the rear and the one nearest the steering column was the most awkward as it was difficult to get to as it's quite close to the column.
It has made a difference as i can now feel the "clicks" when the keys turned.
It was also a good opportunity to replace the bulbs at the back of the clocks.
1989 guardsred 944s2 cabriolet,
1983 metallic claret 924 lux (sold)
Old 06-29-2007, 06:25 AM
I think you are refering to the phillips screw holding the electrical portion. I am not sure whether he is talking about the mechanical portion (pretty difficult), the tumbler assembly (difficult unless you know the drill hole trick), or the electrical part behind the lock.
Old 06-29-2007, 11:16 AM
DVC DVC is offline
Thanks for the help guys! I installed the electrical portion, and it appears as though it had been done before, as there were screws there.
Thanks!
944 LS2 6-liter
Dyno Video
Old 06-29-2007, 08:58 PM
Quality
phoenix_iii's Avatar
Any DIY for late, electrical portion?
85.5 944 NA 5spd - Sold but not forgotten
89 951 Turbo S - Revival in progress...
Old 03-15-2012, 09:14 AM
In the Fires of Hell.....
kdjones2000's Avatar
Yes, tear everything apart around the steering wheel, then use a combination of an offset Phillips head screwdriver and a small / jeweller's screwdriver to remove the two screws.
A mirror also helps.
Good luck, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 03-15-2012, 11:59 AM
Quality
Good luck, Keith
Does that include removing the steering wheel (and airbag), and the side stalks? That doesn't seem like the easy way.
If you mean just the plastic surround around the collar of the steering 'shaft', that's better. Clarify?
Old 03-15-2012, 12:05 PM
You can't get those plastic side pieces off without doing all of the other items you mentioned.... unless the mounts that are screwed in place on both are broken.
Old 03-15-2012, 12:12 PM
What's the "trick" to drilling the hole to remove the tumbler? i need to do this
Old 03-16-2012, 09:59 AM
Where to drill the lock out. Ignition Lock Removal
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 03-16-2012, 10:30 PM
Thanks Larry
Old 03-17-2012, 09:05 AM
Old 03-17-2012, 05:42 PM
Dave Colangelo's Avatar
I had some issues with my ignition switch on my 924S, so i installed this.
the right switch is main power and is one of those cool missile switches. The left one is a non latch switch for the starter. The car is still safe because you need the key to disengage the steering wheel lock. It was a fun project and took maybe 2 hours. The car was not in very good shape and I have more fun doing things like that to it than keeping it stock I keep 944 and 911 100% stock so the 924S is a fun project car.
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 03-17-2012, 06:36 PM
