brake fluid light won't go off
So my brake fluid is at the right level, but the light will not go off. About two months ago the light came on. I checked the fluid reservoir and it was indeed low. After filling, the light remained on. It now goes on and off as I go over bumps in the road and is mostly just on. I wiped out the inside of the reservoir and tried to find the sensor itself. Where is it located? I'm worried the sensor might just be bad.
Pete 1987 944, Silver |
winter-hater club member
try cleaning the wire connections at the cap.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
In my 924S, the fluid sensor is in the cap. As the fluid gets low, the float on the bottom of the cap lowers, and the contacts meet inside the cap itself when the level is too low. Could the float be a bit sticky?
1987 924S (Gretchen), Black on Black, phone dials, modifying for Autocross, daughter's car. (R.I.P - for now) 1978 928E, (Heidi), Minirva Blue, Op-Art & Cork Interior 1993 Mercedes 300DL Turbo (The Black Knight), Black on Black, wife's car. |
meister member
I am not sure how the '87 is set up but on my '83 the brake light can come on with either low brake fluid and/or the parking brake handle not being pushed down all the way. Check your parking brake and the connectors for the switch.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
Misunderstood User
Speedy is correct.
Check the parking brake switch. The float switch is on the reservoir cap. Check the connectors.
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway |
i'm not even seeing anything on the cap. Maybe something came off. Brake handle is all the way down...
meister member
Can you pull the cap and float switch and then check for correct operation using a multimeter? Check for continuity using the multimeter while lowering and raising the float switch.
Do the same for the parking brake handle. Speedy
Misunderstood User
Those are the connectors on top of the cap. When you open the reservoir the float switch is attached to the cap. The float follows the level of the fluid. The float moves easily. You can check the conductivity using the connectors attached to the cap and move the float.
I still would check the parking brake switch. Mine has gotten stuck. A little WD 40 made a big difference. In my opinion, there is more chance for that to get stuck, because of where it's located than the float switch.
I agree with checking the brake handle switch. Mine gets stuck all the time but in my case, the light dosen't come on when the handle is up....I will try some wd40 tonight - good tip.
hmm... my cap is black and my reservoir round, with no wires or anything on the cap.
Misunderstood User
Pete,
My cap on my 83 looks like the picture from Tidy's 88. Your cap is black with no connectors tells me this isn't the original cap. A plain cap tells me there is no float either. You must have (2) wires / connectors somewhere under the hood.
cap is black and the reservoir is round? You are not looking at the power steering reservoir are you? The brake fluid reservoir is towards the back of the engine bay on the driver's side. Power steering is at the front on the passenger's side...
1996 993 C2 1995 968 Cab 1976 Norton 850 |
Misunderstood User
Tidy,
I like your engine compartment; clean, very clean.
