sketchers356's Avatar
Talking Ordering of Thermostat Washers
Hi,
I finally just removed my thermostat's snap ring. I needed to try a variety of methods but eventually got it out with a long pair of 90 degree needle nose pliers with the tips ground down slightly.
However, in the excitement of taking the thermostat out I confused the order of the rubber o ring and washer.
Which order does the thermostat's washer and rubber o ring go in wrt the thermostat?
Thanks again!
Alexander
'75 911S Targa
'86 951 SOLD
Old 07-17-2007, 04:54 PM
Figured it out.
From inside: Rubber Gasket, thermostat, metal spacer washer, snap ring.
Amazing how much easier it is to get the snap ring in than it is to get it out.
I highly recommend using the long 90 degree needle nose pliers though to get it out. For better vision I raised the headlights a tab then I could see the snap ring's holes directly.
Alexander
'75 911S Targa
'86 951 SOLD
Old 07-18-2007, 12:32 PM
adrian1's Avatar
I just did that to mine. Used 45 degree snap ring pliers with bloody hands. Then once it poped out i used i pulling screwdriver to pull it out....
Don't forget the additional thermostat on the 951.
1986 PORSCHE 951 3.0 project has begun!
1989 IROC-Z(Show Car)
1961 Willys Jeep w/ 283 chevy(straight open headers)
1995 Dodge Ram 2500 HD
1981 Corvette 4spd
Old 07-18-2007, 08:17 PM
