944S Boyeee's Avatar
Send a message via ICQ to 944S Boyeee
Fog lights? Is there a bulb?
Just wondering what has to be replaced when a fog light burns out? Is it the whole unit or just the bulb? I know the lens, casing and such are all one piece and there is a bulb involved, but can you just replace the bulb if that is burnt out?
Old 11-27-2001, 09:41 AM
Bob's944's Avatar
Send a message via AIM to Bob's944
on NA'a it's a standard H3 bulb... very simple
Old 11-27-2001, 09:43 AM
So, I just pull the fog light out, and can simply replace the bulb? No need to buy the whole shebang?
Old 11-27-2001, 09:49 AM
Bob's944's Avatar
mine may be different than yours is... not sure .. but mine looks like this and the last time I replaced one was in the parkin lot after I bought the bulb. Took under 5 mins, just take off the lens.
Old 11-27-2001, 09:55 AM
That's what mine looks like. Where did you get the bulb? I noticed that the bulb is set in a lil' steel frame and that plugs into that wire coming from the car. Do I replace just the bulb itself (and if so, how do I pull it out of that steel bracket?) or the bulb/wire piece?
Old 11-27-2001, 10:31 AM
Bob's944's Avatar
Cool
just go buy an H3 bulb, 55w is what that circuit handles, any more without replacing wires can mess things up... the wires can't handle it, other components like relays can mess up too. The wire is attached, like I said it's very simple, you'll see that when you buy the bulb at any parts store, big discount place like walmart/kmart and the like...it's very common.
Old 11-27-2001, 10:39 AM
I'm on my way to Wal-mart now!!! You da man, thanks so much.
Old 11-27-2001, 10:42 AM
Leigh 13's Avatar
One thing to keep in mind with any glass light bulb....be sure not to touch the glass itself! The oils in your fingers can cause the bulb to fail prematurely...just use a towel or something to hold the bulb when you install it.
- Leigh
I'm a firm believer in the philosophy of a ruling class. Especially since I rule.
- Randal Graves
Old 11-27-2001, 11:03 AM
I just tried putting in the new bulb - no light!!! Checked the relay and fuse - but they seem to run both lights. My passenger side fog light works, but the drivers side didn't. I pulled the new bulb out, so I could take it back (seeing as it didn't seem like it was the bulb), and get back my whopping $6 (just joking, I saved it cause I know I'll need another one eventually) and I put the original back in - it worked again as soon as the lil' steel bracket hit the metal hole it goes in. What's up with that? It seemed like touching of the metal against metal turned the bulb back on.
......whatever! It works.
Old 11-27-2001, 11:52 AM
Send a message via AIM to olerebel
I have checked all the fuses, put in a new relay, AND put new bulbs in (without touching the glass) and the fog lights still don't turn on! Any suggestions?
1989 944 n/a
Old 07-16-2007, 07:15 PM
... and I have the h3 55w bulbs in there
1989 944 n/a
Old 07-16-2007, 07:18 PM
Eldorado's Avatar
holy thread from 6 years ago, batman!
pinch down the plug that plugs into the fog light - sometimes they become loose..
after that, i'd suggest replacing the switch.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 07-16-2007, 07:19 PM
Eldorado... your the man. I gave the ground wire a good pinching and it worked! Yeah, the thread is a little old oops
1989 944 n/a
Old 07-17-2007, 05:17 AM
