compression test results
so i'm still trouble shooting this slight miss that i have. i did another compression test again.
1- 180 2- 170 3- 174 4- 180 I know the closer the better, and i read that if theres a difference between 10% then it could indicate a leaky headgasket. does everybody agree these are decent #'s? matt |
look good to me.
Matt, how exactly do you do that test, prep and such?
Good numbers :)
Numbers look pretty good to me. Tonight I had a miss...turned out I forgot to put one of my plug wires back on after fixing a vacuum leak. DOH! can't always be that easy I know, but after the crap I have gone through for the last month getting things put together I think the good Lord knew I might snap big time if I had a legitimate miss LOL.
Your within 10%
Speedy:) |
Looks good to me, Have you checked wires and cap??? How about spark plug Gap???
Also, hold the throtte open when you crank so it gets a full cylinder of air molecules! Otherwise the numbers will not be right...
| All times are GMT -8. The time now is 05:11 AM. |
