winter-hater club member
nynor's Avatar
i finally got the koni struts installed
that i purchased last christmas. there is a marked difference with cornering. the ride doesn't seem a lot harsher, maybe a little. i can't wait to autocross it.
"COOL PRIUS!" - Nobody Ever
Old 08-10-2007, 06:25 AM
Custom User Title
Dave L's Avatar
did you do front and back? I recently did mine and have my first autoX this sunday. The ride shouldnt be harsher unless you also upgraded to stiffer springs. I find my car is "more connected" to the road if that makes sense.
Old 08-10-2007, 07:37 AM
flash968's Avatar
just don't make the all too common mistake of dialing them up too much, thinking it makes things stiffer - it doesn't - it only increases the bump - dial them for your spring rate - the stetting for stock rate would be about 1 turn from full soft
Old 08-10-2007, 08:15 AM
nynor's Avatar
yep. i had a local shop install them. the owner races porsches and set it based on the other components i have.
Old 08-10-2007, 08:21 AM
